Hey guys,
Got a set of 17inch gmax drift 6's, 8 inch front, 9 inch rear, which are currently off the car, the tyres, and have been sanded, fixed, and nearly ready to be painted. I was just going to paint them the same colour, but seeing as of late ive been going for a black and white theme to my car, im thinking of painting the rims a black, rather than gun metal again.
Was just wondering what other people thought, and would like some opinions or ideas of other colours that may suit. Am also in the market for some black wheel nuts.
Heres a few pictures.
If someone could photoshop the rims black/a few other colours that would be much appreciated :)
https://www.sau.com.au/forums/topic/421575-what-colour-to-paint-my-rims/
I think ive decided on black but need suggestions on what finish to go. Ie matte? gloss? metallic?
If someone has the photoshop skills :P would appreciate the help as it would mean i could visualise :)
thanks
hrmmm... the thing is i was tossing up between gun metal or black, so i do want to keep it a darker colour. Thanks for your opinion though. And yes, the pics arent the best lighting-wise
Yes, my car isn't a R33, but it's still the same QM1 white paint; so....
* I wanted a genuine Nissan or Nismo colour
* This colour rim is called Nismo Black
* It's satin in texture (rather than gloss or matte)
* The rims were powder-coated with a resin that resists dust accumulation
* The job was done by Craved Coatings in Penrith
* Black wheels on white paint can affect colour balance in photographs (as in my top photo)
* Fill-in flash though creates a very nice effect as shown by Matt Everingham (as in the bottom photo)
It's still possible to get Nismo wheel nuts. They can scratch easily - and it shows.
Black RAYS Duralumin nuts are matte in texture. They still cost a lot.
But 'copies' of those Duralumin nuts can be obtained on eBay probably at about $60 a set (including lock nuts).
Genuine Duralumins or copies must not be tightened beyond 110Nm
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
