Was a little lighter on the back/legs last night as I've got shed work to do this week.
Still not managing my 8th rep on the bench, though am doing 7 easier and making a point of doing halves a couple halves after that rep to try and build up some more power for 8. The other way would be upping the weight which is usually what I do and after a week or 2 you're doing 7 reps on the final set of the new weight and can do 8 reps on the previous weight easily enough, but I'm not looking to add heaps of bench weight.
Added a little to the chins and made 7 on the final.
Did not plank or row as I knew I had to start digging and my back hasn't been great as it is.
So after a quick 35min session, spent another 90mins doing this, it has to be at least 300 deep.
3m down, another 9m or so to go...
Finished the main trench last night, that was my cardio, sweated my guts out. Took another 2+hrs to do the remaining 7 or so meters. Now just have another 3 or so to go to connect this trench to the main pit.
Fun times. Back is getting a caning. I've made a point of upping my protein shakes and making sure I'm getting enough creatine, I swear I'm recovering from these digs far better than I expected.
That pipe in the trench is to allow water to flow from front to back as that's the low side of the block. Pit up the front and larger pit in the rear that will eventually take overflow from a water tank.
Once that trench is filled in it'll be concreted over and a spoon drain will sit on top so no mowing or maintenance for me.
I could have just relied on the spoon drain to carry water to the pit at the back and not bothered with the pit at the front and the pipe, but given there's a bit of a dip up in the front corner and my apron will be there I didn't want any water saturating that area so made the call to put a pit in and pipe it to the back to pull water away quickly.
Edited by ActionDan
That's pretty hardcore to be doing on your own!
Surprisingly, the ground is much softer than I expected. I can grab my spade, line it up, put my body weight on it with a bit of a lunge and it'll almost go down the depth of the spade.
I bought a mattock in anticipation (and already had a sledgehammer), but have only needed each a few times where concrete had overflowed the box work etc.
It's gotta be done before the weekend so the concreters can put the spoon drain in and do the apron. Digging the tree hole and relocating that tree you see up front will be fun too.
Skipped Gym tonight, had a bit to do on the shed etc.
Finished my pipe work then dug a 500mm+ deep, 6-700 wide hole to relocate a tree, the ground was so bloody hard.
Surprisingly my shoulders/back etc are OK, but my poor girly IT hands are suffering.
The dog was pretty keen to get in the hole and probably dug another few mm down for me lol
ITT: nothing gym related lol
you should have told me you were digging up your yard, I could have sent the Husky down to help
bitch wont stop digging my yard up
girly hands can be fixed by urinating on them................... just saying
I had gloves one. I always do. And I was only doing 2-3 hour stints each night tops.
I just have girly hands. From all my gym glove wearing and IT working, and glove wearing when working on cars.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
