hey guys jut recently i have noticed that when i go over a speed bump i hear the left hand side of the spring creaking and i think it might be time to upgrade the springs mabye put the car on coils, what do u guys think about these coils
http://justjap.com/store/product.php?productid=19810&cat=&page=1
https://www.sau.com.au/forums/topic/421699-springs/
I think the compression rod bushings can cause noises too. and they can are also a common point of failure.
Yep this too, BOTH front comp rod bushes have been replaced on my car it makes a bad creaking noise over bumps and some tight turns. I'd check all your bushes before you go changing to coil overs if thats the only reason why you were thinking of upgrading anyway
https://www.sau.com.au/forums/topic/421699-springs/#findComment-6784747
If your thinking about getting BC Coils make sure you get the BC BR True Style coils, they are the upgraded ones from the V1 and have stronger internals. I have just bought my self a set of those off Boostn Imports in brissy for $1199 delivered to my door.
https://www.sau.com.au/forums/topic/421699-springs/#findComment-6784750
ok so im planing to change my lower control arm bushings as well as my v35 is starting to bug me with the Creek noise. i seem to notice it as usual when going over a Bump or pothole but i took note that if i keep the brake on and while in drive or reverse if i give it just a little gas so that the car pushes the suspension up or down it creaks as well. here is a video someone filmed that is identical to my issue . im 90% sure this si from the bushels but should i change all or just the lower rear ones as most forums posts
https://www.sau.com.au/forums/topic/421699-springs/#findComment-6785972
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
