Hey all,
I bought some rims from a member which were apparently in good condition. Few months went by (tyres were in storage and me overseas for work) I went to a place to fit some tyres on it.
I've bought some ku36's (235/40/18) which fit quite nicely however two of the rims are pretty effd. The guy showed me the rim on the machine as it was wobbling as it was spinning.
He had to put some weight to try and make it work, normally i see up to 40g of weight being added on - however he had to put about 140g on one and 85 on the other.
Going by that the other two good nic will be at the front and these in the rear:
- Is this safe to drive?
- Will the car constantly need wheel balancing/alignment because of it?
cheers for the input guys
https://www.sau.com.au/forums/topic/421962-140g-weight-balancing-safe/
I had a similar probably and was advised that any wobbling whatever on a wheel spells trouble and needed to be professionally fixed before being fitted as it would creates vibrations and imbalance when driving.
So I suggest you get them fixed before driving with them fitted.
Another mate of mine only had minor damage on when wheel and it creates severe vibrations when driving and can actually affect the stability of the car and your wheel alignment too.
Did the seller know the two rims were damaged and had advised you?
Thanks for the reply,
Well on the day when I came to buy them I asked if they were in an accident or damaged - he said they were in perfect condition, now he claims that I should have tested them within two weeks and that I've caused the damage to them even though there isn't a scratch on them. He keeps altering his mind which is the frustrating bit from the wheel balancer doesnt know what he is doing, those rims are better then the ones he has, i've caused the damage and to the latest "what do you expect from 10yr old rims".
He must have known as there is a reason they were all marked (L Front, R Front, L Rear and R Rear) so he would know where to put them.
I can understand they wont be perfect but I took his word thinking it would be ok.
Ill have to chase it up - do you know any places in VIC?
I've been told by some people its fine however not to exceed the 130km/h mark because then you might notice it.....still prob not worth the risk really
I found a place near my house which aint bad, ill get a quote and let people know just in case.
Appreciate the help bud
Edited by milanr34
You can use them no worries, they get annoying at high speeds with really high vibrations, pretty much was drifting on my front that were wobbling hard on the balance machine and anything over 80ks felt like something had broken the amount of vibrations there were prob did contribute to me killing two racks from the vibrations at 140+ while sideways but yeah they are usuable.
Rotating them on the rim? Not too sure what you mean, but he put the rim only first and turned them on (prob to test them out) then came the tyre and balancing.
Alright so as long as im not going 140km/h sideways im sweet haha
tnx fellas
Ill post the results when I visit the shop
"Rotating them on the rim" refers to the fact that if the wheel has a mechanical imbalance (ie more weight on one side than the other) and the tyre is also unbalanced, you can minimise the amount of balance weight that you need to add to the assembly to make it stop vibrating by simply rotating the tyre around the rim a bit, re-inflate and spin it up again. Something of a suck and see approach. Once you find an alignment that vibrates the least, you balance it like that and use the least weight.
But your real concern is really whether the wheel is simply a shit poor wheel (ie, phycisally unbalanced, with more alloy on one side than another) or bent/distorted/out of round in some way.
If it is a simple unbalance issue, then I'd piss the wheels off and not use them because there is no reason for such shittly manufactured wheels to be sold, let alone used. if they are damaged, then you need to find out if they can be massaged back into shape without weakening them further (cast alloy is not as forgiving as steel). And then you need to find out if the cost of doing so wouldn't be better spent on new wheels instead. For eg, if it's going to cost $150 per wheel to fix them, and new wheels from the tirerack.com are only $250+freight.......you have to work out what you'd rather do.
Thanks for the info GTSBoy, they are r34 GTR rims so im presuming they should be good if they were to be put back into shape.$150 i guess it isnt so bad, especially since i just bought the kumhos they are only 2 days old haha
Ill see how it goes. Tnx for the info all
As GTSBoy said, might be as simple as breaking the bead, rotating the tyre and having another go. Tyres have an orientation on a rim, look on your tyre to see red or green dots/markings, this tells the tyre fitter where to put the tyre (red dot near the valve, etc)
I've had balance pretty far out before, tried rotating the tyre a few times and got it down to 40grams.
  • 1 month later...
Cheers for the info, haven't had time to look at this prob as ive been swamped with work..
The guys at OTR surely know how to put a tyre on else they would be known by all SAU members.
Will have to do it one of these days.
Also happen to get negative feed back from the seller haha
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
