Hey everyone,
I am wrecking a S2 R33 GTS T so have a whole heap of spare parts ready to go!
Check out this list below for parts and prices, if there is anything that you need but don't see here then just ask. I may have it.
R33
S2 Rear cradle inc drive shaft/brakes/cables
$200
S2 R33 Doors
$150 each
S2 R33 Boot with spoiler and hinges
$200
S2 R33 Bonnet
$300
S2 R33 Front Seats
$80
S2 R33 Rear seats
$35
R33 Rear Bumper
$100
R33 Stock Cooler
$80
R33 Front Rio
$50
R33 RHF Guard
$100
S2 R33 RH Side Skirt
$50
S2 R33 Door trims
$20
R33 Switch pack rits
$50
RB25DET Ignition coils & Plugs
$100
R33 RHF Fog Light/Indicator
$100
Seatbelts
$50
RB Radiator
$20
S2 R33 Headlight
$400 pair
S2 R33 Grill, Skyline Plate
$30
S2 R33 Centre Console
$30
S2 R33 Tail lights
$500 pair
S2 R33 Washer Bottle
$20
S2 R33 Coolant overflow
$20
S2 R33 Rear pods
$80 pair
S2 R33 Glove Box
$30
S2 R33 Boot insert
$30
S2 R33 Speedo
$50
S2 R33 Centre Dash
$50
S2 R33 Dash Surround
$50
S2 R33 Windscreen Wipers
$30
S2 R33 Suspension
$100
S2 R33 RH Control arms – Upper & Lower
$100
S2 R33 Rear steering rack
$50
S2 R33 Rear Strut
$50
S2 R33 Door Inserts
$50
S2 R33 Parcel Tray
$50
S2 R33 Air box
$150
S2 R33 Break Booster
$50
S2 R33 Hand brake
$40
S2 R33 Clutch slave & Pedal Box
$50
S2 R33 Front Steering rack
$50
S2 R33 Front Cradle
$100
S2 R33 Sway Bar & connection part
$70
R32
R32 Diff
$300
R32 Front Brakes and vertical link
$200
RB20DET Engine no loom
$400
Rb20DET Gear Box
$200
All prices are negotiable, make an offer. Need these parts gone!
Cheers,
Leong
0401 526 517
[email protected]
Do you have a front strut brace ? also i am interested in door trims and other interior bits eg sun visors etc if in good not faded condition can inspect tomorrow afternoon
  • 1 month later...
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
