Hey everyone,
I am wrecking a S2 R33 GTS T so have a whole heap of spare parts ready to go!
Check out this list below for parts and prices, if there is anything that you need but don't see here then just ask. I may have it.
R33
S2 Rear cradle inc drive shaft/brakes/cables
$200
S2 R33 Doors
$150 each
S2 R33 Boot with spoiler and hinges
$200
S2 R33 Bonnet
$300
S2 R33 Front Seats
$80
S2 R33 Rear seats
$35
R33 Rear Bumper
$100
R33 Stock Cooler
$80
R33 Front Rio
$50
R33 RHF Guard
$100
S2 R33 RH Side Skirt
$50
S2 R33 Door trims
$20
R33 Switch pack rits
$50
RB25DET Ignition coils & Plugs
$100
R33 RHF Fog Light/Indicator
$100
Seatbelts
$50
RB Radiator
$20
S2 R33 Headlight
$400 pair
S2 R33 Grill, Skyline Plate
$30
S2 R33 Centre Console
$30
S2 R33 Tail lights
$500 pair
S2 R33 Washer Bottle
$20
S2 R33 Coolant overflow
$20
S2 R33 Rear pods
$80 pair
S2 R33 Glove Box
$30
S2 R33 Boot insert
$30
S2 R33 Speedo
$50
S2 R33 Centre Dash
$50
S2 R33 Dash Surround
$50
S2 R33 Windscreen Wipers
$30
S2 R33 Suspension
$100
S2 R33 RH Control arms – Upper & Lower
$100
S2 R33 Rear steering rack
$50
S2 R33 Rear Strut
$50
S2 R33 Door Inserts
$50
S2 R33 Parcel Tray
$50
S2 R33 Air box
$150
S2 R33 Break Booster
$50
S2 R33 Hand brake
$40
S2 R33 Clutch slave & Pedal Box
$50
S2 R33 Front Steering rack
$50
S2 R33 Front Cradle
$100
S2 R33 Sway Bar & connection part
$70
R32
R32 Diff
$300
R32 Front Brakes and vertical link
$200
RB20DET Engine no loom
$400
Rb20DET Gear Box
$200
All prices are negotiable, make an offer. Need these parts gone!
Cheers,
Leong
0401 526 517
[email protected]
Do you have a front strut brace ? also i am interested in door trims and other interior bits eg sun visors etc if in good not faded condition can inspect tomorrow afternoon
  • 1 month later...
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
