Don't you know, the key to weight saving in a stagea is to do a big dump before driving... :domokun:
But seriously, like others have said, i don't think you have a whole lot to gain unless you completely want to destroy the nicety of a stagea. Always drive around with under a 1/4 tank, saves you 45-50kgs in fuel. I notice a difference in acceleration between a near empty tank and full tank.
Edited by NickM91
  • Replies 70
You would be surprised- many M35 owners have competed in club motorsport event with great success. They are actually pretty handy on the track. Scotty, Jetwreck, Myself, Wagon_boy, Andys old car, off the top of my head have all seen track time.
Stageas post some of the fastest times in SAU NSW texi events. Full blown race car, no, but with the right mods you'll be rounding up people in what would appear to be "racier" cars.
Terrible auto is the first thing that comes to mind.
I feel it would be far easier for an rb36 c34 to make better power and handling for far less money.
Im not saying it's a bad car. Just not an ideal race platform without a bottomless pitt of cash.
There seems to be alot more limitations and barriers sooner with thos chassis/engine then dealing with say a silvia skyline evo wrx base ect.
Sure, thats why I went and bought a 180 for the track.
You don't have a transgo shift kit yet do you? Must say even with the trango in both transmissions, they still improved a lot in the S2 cars. With the right mods, and certainly not huge amounts of cash, you can have a pretty capable car. You went for a spin in Jetwrecks car, so that gives you a fair idea.
The shifting was alot better.
Im hoping someone gets game enough for a Manuel conversion to see how much this auto box limits performance.
Good tip. I like it. How big are the fuel tanks? 80litres?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
