Hey guys,
I've spent quite a lot of time searching through the N/A sections to try and find advice on what needs to be done to create an amazing N/A with great responsive-ness.
So far all i have managed to find is advice on how to make better power figures (OMG!!11!! BIG NUMBERS!!1!)
As a P-Plater in Vic i cannot legally drive anything that is decently powerful so the best i have to play with is an N/A that sticks within a certain power-weight ratio and as i highly value my licence i have to stick within my confines..
SO!
What needs to be done to an N/A RB20DE to make it an exceptionally responsive unit? I'm not after low numbers in a straight line, as it's daily driven i need it to be practicle and sensible but i would also like to be able to blow the doors of a turbo'd car when it comes to winding roads =]
Cheers,
Cory.
  • Like 1
https://www.sau.com.au/forums/topic/422682-na-r34-25gt-response/
the only thing that will let you blow the doors off a turbo car when it comes to winding roads would be some sort of smoke screen or dropping tyre spikes out the back.
good tyres, decent suspension and bigger brakes will make you as fast through the corners as a turbo car with the same stuff, but as soon as they get on the gas they will be faster.
you can make it more responsive with shorter diff ratios as suggested and advancing the timing so it's pinging it's arse off, but you are still pushing shit up hill, so to speak. the rb20 isn't exactly responsive to start with compared to other engines out there. driving style will make the biggest difference. drive around keeping it above 4000rpm will help. or pull the engine out and bolt in a rb25 (although if you have a r34 25gt then you already have a rb25 in there)
or sell it and buy something lighter and more powerful. it may be fwd, but there are plenty of light hatches that will beat a NA skyline both in a straight line, and in the bends.
Is RB20DE a typo?
Cause your profile thing says you have an R34? (RB25)
Sell the skyline, buy a B-series Honda.
I had an N/A R34 for 3 years, without the power you feel the weight....bad.
If i had my time back, I would have spent the past 3 years in a Honda.
Thanks for the replies guys,
Yeah sorry Lindz, that was a typo.
I like my Nissans, mainly the Skyline and FWD's just feel wrong to me, personal preference though, not hating on them or anything.
The Skyline is probably the only thing i can currently legally drive that would satisfy my tastes, if i could drive a 350z i would have one in a heartbeat..
If i could turbo it or throw another engine into it i would but the P-Plate restrcitions would still get me.. I'm not a hoon or anything, believe me, but a little bit more power would make me smile. Too embarresed to take the NA to a track haha.
So far we have shorter diff ratios suggested, anything else at all?
Cheers,
Cory.
how much do you want to spend? you won't get a NA skyline fast for cheap. even with a small amount spent you will still get beaten by commodores and falcons in a straight line, and small buzz boxes in the corners.
as for fwd feeling wrong, it isn't until you are "hooing" that you actually notice the difference. driving to the shops and back you won't be able to tell the difference at all.
Not looking to spend heaps as it's just not justifiable, i'll get my opens in 2 years and would prefer to have a bit to splurge on something with a much more powerful base.
My girlfriend has a VW Golf, FWD, that i've driven on many an occasion and i'm not sure if it's the German design, weight or shape but it feels terrible in comparison to the RWD Skyline.
My opinion hasn't changed, Honda.
A mates lightly modded EK hatch was dead even with my 34 in a straight line.
He had a few suspension mods (coilovers/braces/sway bars) & he left me for dead in the twisties.
He then dropped a B16 in it......you get the picture.
Don't get me started on DC2R's.
Trust me mate, once you drive one you'll realise, they aren't you're "average" FWD.
what model golf? if it's just the base model then what you are complaining about has nothing to do with it being fwd. it has more to do with it not being marketed/designed as a sort of sports car. i could use the same sort of analogy as you and say that because the missus SSS is much nicer to drive than my vt wagon, rwd cars are shit compared to fwd.
i have a twin throttle body intake ill be selling soon, the whole plenum incl intake EVERYTHING as im going itb on my 25/30.... if interested pm me ill let you know when im ready to sell it, have a quick look i think theres pics on here or the engine used to be skit_r31's so have a look there. cheers
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
