I am a mechanic guys I have been involved with and have driven very fast cars I want a turbo yes but I don't froth over turbos like some.
I don't mind having less power if I can use the power I have IE: racetrack style torque profiles.
I have seen rb30 heads that flow enough for 330hp which would want my engine to spin at about the mark I am looking for 8k which is where I will be shooting.
My engine stand comes soon dedicated to this build pistons are next $700 ill be contacting crankshaft rebuilders for a price to do the crank and I am thinking 26 rods.
The head is back to me before machining so I can work out belt's and other little things a mate just blew to 30's at the mattsuri comp so ill be having one for bolts and other parts.
Edited by pf.
Like a turbo car.......?
Nothing like a turbo car. The power will actually be instantaneous. If you have a turbo that comes on only over 4K, even once you're over those revs and stand on it, it takes time for power to appear. Sounds like some people may be surprised at how much a very driveable lower powered engine can still pull a lap time down.
I know, I used to have a cammed RB30 NA. Power and Torque was nice. Not blowing anything away but it was a nice delivery.
I'm just saying, theres a reason why car/engine manufacturers are going DOHC or Quad cam when in V configuration. Just remember there is no VCT with the RB30 head
But anyway, I'm not going to say anymore. Advice has been given, noone is forced to take advice, and thats fine. Everyone is entitled to their own opinion etc.
i actually meant the 5.5l new small block lol
But that is a smaller engine with new tech. A bit like how the rb25 was better than the rb30. However in this case the op is taking the smaller, newer engine and bolting on the old tech.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
