  • Replies 82
Hey hey hey, I've got a wrecked ankle and I'm still squatting 3x a week for 3 sets of 10 reps, granted it's only a bit over 50kg, but that's more than half my body weight on a crap joint. Plus I'm stil doing SLDL and some lunges.
I'm also just about to buy a rack once I settle on a bench.
A dodger I may have been, but no more!
well I've done challenge one, I wish my gymbros were up for doing squats more than once a week, instead of insisting on fluffing around with cables etc.
TTT are you a big fan of Starting Strength or just squatting?
Is it normal for gyms to not allow photos / videos? in mine it's expressly forbidden.
Was watching a dude doing squats on the smith machine yesterday....he only had 70kg worth of plates on the thing, but holy jesus his "form" was horrific - even considering there is no real correct form for using this stupid machine. He was almost literally touching the ground with his ass, but it was a very violent descent and more or less bouncing off maximum ROM. Made me cringe hard.
  • 3 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
