haha ive had a moment in 4th at 100km+ on a wet freeway next to a hsv SLIDEWAYZ
show us the footage whatisname!
i might get hankooks K104s soon see how we go with the real wheel traction, if its still crap you guys are all paying for those tyres!!
  • Replies 46
Barring wet/greasy conditions, i'm running falken's - the only time i loose grip is near max leaving 1/2, and then 3rd, 4th when it's a tad wet. - although the tires will need changing soon, but they've not been ripped at all.
I'm a pretty new 'line driver, and getting used to the Rwd has been a bitch after many years of BM's and Saab's. (Esp 90Deg Corners under power!)
I have no idea of my output - '96 St, T04, Mines, Pod, High Flow Cat, Adjustable Front Shocks, stock rears - etc, etc...
I'll see if I can get it hosted tomorrow at work - if I can find it. If Martin (Donnon) is reading this he should remember that pass - he's leaning against the wall in the vid :D
Edit: I found the vid. It's very dark, so I'll see if I can lighten it up a touch at work tomorrow. It doesn't look all that scary in the video to be honest - just a little wobble and that's about it.
It is sooo true that size isn't EVERYTHING when it comes to traction. I had Falken Azenis 255/40/17's on my R32 with 217rwkw and it spun like crazy from 1st through to 3rd. If you took off normally, then hammered the throttle in second the tail would end up sideways like crazy. DECENT tyres go a long way, as aforemetnioned. Suspension & alignment setup is crucial, I think Sydneykid posted up what his ideal settings were for 200 plus rwkw cars...have it saved somewhere...will try to find the info and post it up.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
