  • Replies 68
  • 3 weeks later...
Got some good results today!! Intercooler holding me back at the moment with rising intake temps. It put out 527rwkw on 25psi. Change cooler, raise boost to 32psi and you can imagine whats going to happen lol but yes my goal of 500rwkw has more then been achieved! :)
There's dyno graph. Yes go to Just Engine Management on facebook to see all vids. New cooler and more boost will be coming soon :)
Cus you know.... It needs more :P
  • 1 month later...
