Flat changing - not taking your foot off the accelerator when changing gear. Gets mad seconds, thirds, fourths etc... hurts the drivetrain (and motor if no rev limiter)
Double clutching - releasing the clutch in neutral between gear changes. Takes ages to change gears, but will at least go into gear if having syncro issues or hard to shift boxes.
are there any other techniques we could use when drag racing. The flat changing sound good. :)
Double declutching eg from 4th to third........clutch in-into neutral-clutch out- bring revs up to match your current road speed- clutch in-into 3rd-clutch out mostly used when downchanging, Your clutch will live a long and happy life.
Flat changing- go pedal flat to the floor-hold it there while you change gear. Your clutch will die very young.
Flat changing in a syncro gearbox is not a good idea.
Maybe when you install a straight cut dog tooth box it will be good.
Double shuffling or double clutching is probulary best described on forums such as "Diesel Landcruiser Australia", "Mack Truck USA" and "HQ Holden heaven"
However, heel and toe down shifting is all good!
Thanks alot for the help ... yeah i'm familiar with the theory of heel & toe it's just a matter of attempting it. But yeah, thanks again for the info on double clutching & flat changing.
Once again, you can have a helical cut dog box or a straight cut synchro box. Meh...
I just want to know what granny shifting is!?
hehehe....fast and the furiNAWS.
I granny shift all the time...if I don't i look like the biggest dick during peak hour :D
heel and toe is not double clutching in itself. simplest heel toe has nothing to do with double clutching, just to aid in downshifting whilst braking (getting revs high enough for lower gear).
of course u can add double clutching to that, but in a syncroed gearbox there isnt all too much point
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
