Does seem a little high, but wow where do you start.
1) what oil are you using
2) How old and how many k's has it done
3) do you drive teh car regularly or does it sit in the garage for weeks
4) what's the road like? freeway and sitting on 3500rpm for an hour, suburban stop start, backstreet hill climb course.
5) did it get back down if you took it easy and dropped the revs
There could be a heap of reasons not related to a "fault" so rule those out first.
Also again way too many unknown's but most good oil is fine up to around 130deg.
How far off is 150 compared to where it normally sits for you?
Oil cooler would easily get that down.
I have the same issue . I have a r33 gtr. Completely stock.
Oils temp goes up to 130-140 and increasing - if I just cruise at 120kph on freeway for any extended period.
So I have to back off to 100kph. Which is frustrating.
I use top grade motul. Car is driven 1-2 times per month.
What is wrong with it- as I'm using it as standard and sure this should not be happening
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
