Wrecking a 1998 R33 GTS-T S2 40th Anniversary Edition Im sure i have missed a few parts let me know what you need ill take a look if i have it. Pictures are available upon request via MMS (Mobile), Email or Forum PM.
Vehicle Colour: White
Transmission: Automatic
Contact: 0401 025 251
Unavailable Parts:
Guard Liners
Complete Engine
Engine Loom
Radiator
Available Parts:
Engine / Suspension / miscellaneous
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) $550
Rear subframe $100
Auto Diff $200
Driveshafts $50
HICAS $50
Power steering bottle $20
Brake master cylinder $50
Sway bars $20 each
Steering column $20
Stock Rims inc Tyres $200
Stock Suspension $100
S2 RB25DET Auto ECU $50
S2 RB25DET Auto Transmission (112,xxx) $400
Fuel tank $40
Front/Rear Window Screen Wipers $20
Front wiper motor $20
Rear wiper motor $20
Handbrake assembly & Cables $50
Exterior Parts (White)
Driver Side Door $150
Passenger Side Door $150
L/H QTR Glass $50
R/H QTR Glass $50
Front Windscreen $50
Rear Windscreen $50
Front Guards $150 a pair
Side Skirts $150 a pair
L/H Tail light inc. cover $20
S2 Skyline Garnish $50
S2 Front Grille $50
S2 Headlights (Damaged) $50 a pair
Nismo Clear Side Indicators $50 a pair
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators $400
S2 L/H Door Mirror $30
S2 R/H Door Mirror $30
S1 R/H Dorr Mirror $10 (Midnight Purple)
Interior Parts
Auto Cluster (112,xxx) $70
Dash Cluster plastic surround $10
Lower Fuse dash trim $20
S14 Airbag Steering Wheel $70
S2 Dashboard $100
S2 Dash Fasica inc. switches/vents/auto plastic gear surround $120
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) $400
Sun Visors $40 a pair
Interior Carpet $40
Glove box $20
Center console $50
Heater core $50
Aircon core $50
Heater fan $30
Indicator/Wiper switch assembly $50
Handbrake lever $20
Seat belts (set of 4) $50
Roof lining $40
Skyline Door Scuff Kick Plates $40 a pair
Door seals $40
Boot seal $20
A pillar trims $40 a pair
B pillar trims $40 a pair
Rear Vision Mirror $20
Edited by DarkRyda
  • Replies 140
Lower Control Arms - SOLD
Pictures Below:
Steering column surround $20
Indicator Stalk / Light Stalk $60
Window Weather Shields $50 a pair
Center console $50
Climate Control Unit $50
Genuine handbrake boot $20
Hey bud
Did you have the clutch fan + plastic housing?
Also did you have the electric fan infront of the radiator?
Hey mate don't have the parts your after sorry champ.
Dome Lights (Front / Rear) $30 a pair
Roof Handles $20 set
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Heater Core - SOLD
Windscreen wiper washer bottle - SOLD
Front Guards $150 - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
