Wrecking a 1998 R33 GTS-T S2 40th Anniversary Edition Im sure i have missed a few parts let me know what you need ill take a look if i have it. Pictures are available upon request via MMS (Mobile), Email or Forum PM.
Vehicle Colour: White
Transmission: Automatic
Contact: 0401 025 251
Unavailable Parts:
Guard Liners
Complete Engine
Engine Loom
Radiator
Available Parts:
Engine / Suspension / miscellaneous
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) $550
Rear subframe $100
Auto Diff $200
Driveshafts $50
HICAS $50
Power steering bottle $20
Brake master cylinder $50
Sway bars $20 each
Steering column $20
Stock Rims inc Tyres $200
Stock Suspension $100
S2 RB25DET Auto ECU $50
S2 RB25DET Auto Transmission (112,xxx) $400
Fuel tank $40
Front/Rear Window Screen Wipers $20
Front wiper motor $20
Rear wiper motor $20
Handbrake assembly & Cables $50
Exterior Parts (White)
Driver Side Door $150
Passenger Side Door $150
L/H QTR Glass $50
R/H QTR Glass $50
Front Windscreen $50
Rear Windscreen $50
Front Guards $150 a pair
Side Skirts $150 a pair
L/H Tail light inc. cover $20
S2 Skyline Garnish $50
S2 Front Grille $50
S2 Headlights (Damaged) $50 a pair
Nismo Clear Side Indicators $50 a pair
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators $400
S2 L/H Door Mirror $30
S2 R/H Door Mirror $30
S1 R/H Dorr Mirror $10 (Midnight Purple)
Interior Parts
Auto Cluster (112,xxx) $70
Dash Cluster plastic surround $10
Lower Fuse dash trim $20
S14 Airbag Steering Wheel $70
S2 Dashboard $100
S2 Dash Fasica inc. switches/vents/auto plastic gear surround $120
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) $400
Sun Visors $40 a pair
Interior Carpet $40
Glove box $20
Center console $50
Heater core $50
Aircon core $50
Heater fan $30
Indicator/Wiper switch assembly $50
Handbrake lever $20
Seat belts (set of 4) $50
Roof lining $40
Skyline Door Scuff Kick Plates $40 a pair
Door seals $40
Boot seal $20
A pillar trims $40 a pair
B pillar trims $40 a pair
Rear Vision Mirror $20
Edited by DarkRyda
  • Replies 140
Lower Control Arms - SOLD
Pictures Below:
Steering column surround $20
Indicator Stalk / Light Stalk $60
Window Weather Shields $50 a pair
Center console $50
Climate Control Unit $50
Genuine handbrake boot $20
Hey bud
Did you have the clutch fan + plastic housing?
Also did you have the electric fan infront of the radiator?
Hey mate don't have the parts your after sorry champ.
Dome Lights (Front / Rear) $30 a pair
Roof Handles $20 set
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Heater Core - SOLD
Windscreen wiper washer bottle - SOLD
Front Guards $150 - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
