  • Replies 160
Posted Images
What sort of thoracic spine injury and how did they diagnose it?
I dont know about you but if I had a spinal injury, I probably wouldnt be going to a chiro because all they do is spinal manips which isnt necessarily going to beneficial. Besides, if you have a good physio they should be able to do everything a chiro can do
Physio and Trigger Point therapist both said it was a thoracic spine facet joint injury.
I wanted to get an ultrasound last week but my GP told me to wait, maybe I should go back this week and just say I want one.
Different people are telling me different things, some people are suggesting chiro and others suggesting physio.
+1 for physio or myo as opposed to Chrio. (For me the Myo I have is head and shoulders above the physio's I've seen, they have the same anatomical understanding but also are fantastic at deep tissue massage and myofascial release techniques that the Physio doesn't go near.
I think a good SPORTS physio/Myo is better again, and there are people around my area who identify distinctly as such.
The (free) physio I see at the hospital for my ankle is always saying how great it's going but she's only thinking from a basic functionality point of view, can I walk and jog pain free for a bit? Yes then you're doing great compared to the last guy I saw who can't walk unassisted.
A decent sports centric therapist realises that you want hih level function, not just basic movement, and works towards that. I'm about to leave my free physio I think and head towards one of the sports specialists for higher level assessment and to work out how to help stop my bad foot rotating outwards and rolling inwards when load is placed on it, which f**ks squatting up badly for me, and also strains my god side as it carries much more of the load.
+1 for myo over chiro. There is one upstairs from work. I've had days where I could barely walk properly from back pain and after 30 mins on the table I'm much better. It hurts like hell while I'm getting wailed on, but afterwards I feel much better
Hammy continues to be an issue despite dropping all leg work with the exception of walking for normal daily activities and walking the dog once a night, short walk, 2ks.
I note my lower back on the same side is tight and not moving freely also, similar spot to when I had the SIJ issue.
Is there a chance the hammy is being strained by poor mobility above and below it if that makes sense?
I might go back to the myo and get another hour session and this time not train the day after it thinking it's ace.
I had dry needling done, isn't that the same thing?
It's not quite the same thing; similar principle but trigger point doesn't use needles and allows the therapist to focus on one trigger point at a time. I feel trigger point enables the therapist to get deeper into the muscle fibres.
To me your hamstring sounds like an active trigger point; referring pain either locally or to another location along a nerve pathway.
To me my hamstring sounds like aids =\
Might have to cut it off.
Hahaha awwwww Dan!
If it helps I'm feeling the exact way about my shoulder blade atm
The thought of slicing it open is actually relieving to me lol
However, since my last physio visit on Friday (this physio was a hundred times better) it's actually feeling better than it's ever been. She said she hasn't come across someone so stiff in the thoracic spine before :( She loosened me up and manipulated me. I had an intense migraine for 2 days but feeling a lot better today; just constant cracking.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
