door trim pockets: $15 for the pair
door handle covers: $10 for both
catch can (a bit rough, no bracket, but comes with both adapters): $15
door trims ( a couple of little tears) : $25 each without the pockets and handle piece OR $35 with pockets & handle piece
the interior piece that goes below the steering wheel, the one that covers the fuse box and the air vent : $30
gtst front bar (looks dirty in pic because of dust), still in good condition nothing has been cut from it : $150
center console trim: still sits in perfect but is rough and will need matte black paint on it: $20
rear light piece, right hand side : $30
front windshield left and right plastic bits: $20 for both, the one on the drivers side has a dint in it
drivers side door handle (will take a pic of it tomorrow): $15
photos here (sorry they are in random order) http://imgur.com/a/0j0tN
located in western sydney, liverpool, NSW.
Edited by IM-32-FK
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
