So on the weekend I put different front coilovers in my gtst and now the steering wheel is shaking like crazy at about 120. I don't know if maybe a wheel weight has come off and its just a coincidence that it did it after i swapped struts. Besides an inbalance or a bent rim what could cause this? Could it have anything at all to do with the different coilovers?
Cheers!
Damper adjustable? What settings are you using? Try upping the hardness if it's at full soft.
Wheel shake could also be bad tyres (I had that issue a while ago). Also have a look at your steering rack mounts and bushes.
Yeah damper adjustable and I've got them reasonably firm at the moment. But my front tyres are really bald on the inner edges. Getting a balance today to see if it improves anything. Cheers. Wheel alignment shouldn't really cause shaking though I don't think.
mine would shake on the freeway around 110...turns out it was toeing out, on one side more than the other...not sure why, just wear and tear on bushes I suspect.. Probably caused by 200,000kms of my aggressive turning to the left or something I dunno..lol
...once aligned it was fine, even with the crappy tyres..
If you have issues best thing is usually take it to a alignment shop..I mean we can all sit here and play guessing games or you can just go spend 50$ and find out the problem and hopefully have it rectified,,,
Iv'e had this same issue with the same car since I bought the car.
I've changed radius rod bushes. Got new tyres. Balanced them. Twice. Dad 3x Front and Back Wheel alignments. Still have the problem.
I'm thinking its the aluminium spacers on the wheels. They just fit looselely over the studs and move around until you bolt the wheel in place. Obviously causing balance issues.
I need to find a way to stick spacers perfectly to the back of the wheel instead of the hubs.
OR better, does anyone know of any spacers that fit Perfectly centre on the stock GTS-t hubs?
isnt this why you buy hub centric spacers :blink:
Yea I guess so but I've only recently turned my attention to this and I'm new to it all. I took it to a wheel shop about the problem. Got them to fit another set of my own supplied control arms and hubs and they said they'll fit hubcentreic spacers on it but when I got the car home it was just loose aluminium plates with universal holes to fit the studs on them.
I only need about 10mm extra clearance on top of stock hubs so the rim spokes dont hit the brakes.
http://www.isc-performance.com/oilcoolers.html
These look huge.
Got a balance and all good ! Thanks for the help lads
Got to hear. Damn your luck :)
Edited by sonicz
Should have taken it back to them and ask wtf is this slip on crap.
GKTech have wheels spacers as well ;)
Man I don't mind slip on if its hub centric and properly symmetrical. My impression was this is what they will fit.
Thanks for pointing me to Gktech!
I found these
http://www.gktech.com/index.php/4-5x114-3-10mm-hub-centric-slip-on-spacers.html
That's all I friggin need :D Don't need the ones with the studs.
Ordering on Monday. Though I don't know what exactly "on back order" means in terms of how long till I get them
Maybe I should just go for the 15mm ones in stock and hope I don't need to flare the guards. I'll have a wider track. :cheers:
Edited by sonicz
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
