Lol That was fast. I asked essentially the same thing got shit all answers.
"What is the easiest way to fit brand new quality bearings on my car?. I will be doing it with a friend. Hes changed bearings before on a few times on standard cars, Starlet bluebird etc,"
http://www.skylinesaustralia.com/forums/topic/423302-had-both-front-hubs-control-arms-replaced-problems-now-worse-no-more-money-diy/
Guess I need to just cut the fluff and get to the point.
So a hammer and a piece of wood wont do it then? Are you going genuine Nissan bearings?
Edited by sonicz
http://www.kudosmotorsports.com/catalog/nissan-front-wheel-bearing-kit-genuine-nissan-300zx-z32-skyline-r32-2wd-r33-2wd-r34-2wd-p-303.html
Front Wheel Bearing Kit - Genuine Nissan 300ZX Z32, Skyline R32 (2WD), R33 (2WD) & R34 (2WD)
This Listing Suits The Following Application(s):
  • Nissan 300ZX RZ32 NA (VG30DE, 07/1989 - 07/2002)
  • Nissan 300ZX RZ32 TT (VG30DETT, 07/1989 - 07/2002)
  • Nissan Skyline HR32 GTS (RB20DE, 05/1989 - 08/1993)
  • Nissan Skyline H©R32 GTS-T (RB20DET, 05/1989 - 08/1993)
  • Nissan Skyline HR32 GTE (RB20E, 05/1989 - 08/1993)
  • Nissan Skyline ECR32 GTS25 (RB25DE, 08/1991 - 08/1993)
  • Nissan Skyline HR33 GTS (RB20E, 08/1993 - 05/1998)
  • Nissan Skyline E©R33 GTS25 (Series 2) (RB25DE, 01/1995 - 05/1998)
  • Nissan Skyline E©R33 GTS25 (Series 1) (RB25DE, 08/1993 - 01/1995)
  • Nissan Skyline E©R33 GTS25-T (Series 2) (RB25DET, 01/1995 - 05/1998)
  • Nissan Skyline E©R33 GTS25-T (Series 1) (RB25DET, 08/1993 - 01/1995)
  • Nissan Skyline HR34 20GT (RB20DE Neo 6, 05/1998 - 06/2001)
  • Nissan Skyline ER34 25GT (RB25DE Neo 6, 05/1998 - 06/2001)
  • Nissan Skyline ER34 25GT-T (RB25DET Neo 6, 05/1998 - 06/2001)
Whirte GTS-T, You seem very knowledgeable so I'll ask you for some advice if you don't mind.
Recently blew almost $400 by paying a shop to change my upper control arms (the car came out worse at the end). Because it had a noise, we agreed he would tighten the f**k out of the bolts. The steering now feels very hard to turn, and cornerning is difficult, (but the noise is gone) you really have to battle the car steering wheel get it to go around a corner whereas before it was peppy and loved to turn in.
I am not sure if the second hand control arms are just stiffer/shitter or its because he tightened everything too hard, but I want to re do all the bolts. Do you happen to know the torque settings for the bolts around there?
Secondly, when I'm changing the bearings It will be a good time to fit adjustable camber arms. Just curious how badly do the stock camber control arm bushes get worn here because I am perfectly happy with my current -1.7 front camber with the stock arms, so I would be changing them just to replace the worn bushes.
These bushes here.
Here are the stock arms out
Sure those bushes will not cause much trouble even if they are stuffed? Worth going to a set of new adjustable control arms like the orange ones in the pic just for the sake of those new rubber bushes? Frankly I'm more concerned about the bushes in the upper control arms themselves where the camber arms link up but I have NFI how one would replace those...
Edited by sonicz
Something else must be wrong. It shouldn't matter if you locked the upper control arms to the chassis, you should still be able to turn the steering. Steering pivoting happens in the upper bearing and lower bearing on the upright. I seem to recall you mentioning that you swapped your uprights to try to solve your wheel bearing issue? Then you also swapped the other bearings and the problem could well be there.
If your worried about NVH (Noise Vibration Harshness) don't fit aftermarket rose jointed Upper control arms. If you want more/less camber then install offset bushes.
The bolts for the bushes should be done up in a laden position, preferable at ride height, with the vehicle on flat ground. However due to the position of the arms this may not be possible on a four post hoist. If using a two post hoist, they should be done up with a wind up jack under the Lower control arm to simulate the loaded position.
Also if the camber is altered at all, it will also affect the castor and toe, so a wheel alignment should be carried out after any changes.
Not really worried about NVH, just hate clunkiness and poor handling. The adjustable camber arms are just solid pieces of metal with rubber bushes on one end that bolt to the chassis end, not rose joined?
I can get these for as low as $200 for a pair to do both front sides, I believe bushes cost around this much anyway and a PITA to change yourself at home. This is why I was asking if these units will help out making the car feel newer/better.
http://www.ebay.com.au/itm/Nissan-Skyline-R33-R34-Front-Upper-Camber-Arms-/130793547716?pt=AU_Car_Parts_Accessories&hash=item1e73e727c4&_uhb=1
$(KGrHqUOKiEE5dCn,Kj(BO(W,4z1pQ~~60_12.J
Thankyou for getting those torque specs. I too was unable to find the service manual for the r33, but easily for the 34, However, I assume all the torque specs would be the same between the 34 and 33?
To be honest I am going to need to ask a mehcanic which bolts are which. I am not sure which bolts they are reffering to. I would much rather they had a diagram with arrow pointing to the bolts and the torque specs.
Edited by sonicz
Thanks man. Doh I forgot to add ball joints to my cart. Now I have to pay again for postage.
Is there anything else when doing the front bearings I can change in working in that vicinity I am forgetting?
So far I have
-New tie rod ends
-New Front wheel bearings
Whiteline Polyurethane Radius rod bushes (I don't want rose jointed caster rods)
-Soon to order new Ball joints http://www.kudosmotorsports.com/catalog/kudos-motorsports-ball-joint-front-rear-outer-lower-nissan-200sx-s14-s15-skyline-r32-2wd-front-only-r33-2wd-r34-2wd-p-214.html
-Still undecided If I should order the adj Camber arms.
Did I miss anything?
See that pic you reposted with the Orange arms. What are those bushes in the upper control arm. The ones between the black bits you said are marked with an "L"
Lastly, the car will be jacked up at the centre of the front cross-member with a hydraulic jack, and I will have 2 jack stands on the front only. So your saying before I torque any bolts that connect to bushes, I should place a seperate wind up jack underneath the lower control arm, and raise it until the whole hub assembly sits about where it would at ride height?
Edited by sonicz
Oh, by the way....rose jointed caster rods kick urethane bushed ones all over the place. They hardly add any NVH, yet they massive improve wheel location and actually give you the ability to put some real adjustment in there. The adjustable urethane ones give you a bee's dick of adjustement. I have urethanes in mine at the moment (so the car could get inspected - had to be legal) and am hating it. Will be putting the solids back in as soon as I have an opportunity.
Sure, they are defectable, but they are very likely to be overlooked by a roadside cop, and are easily changed for a roadworthy inspection on the very off chance you actually get busted. I have nearly everything else on my car as close to legal as possible....except those rods. They are worth it.
Edited by GTSBoy
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
