This is a brand new in the box R32,R33,R34 (RB26DETT) Carbonetic (ATS&Cross) twin disc carbon clutch (ACN23210-14). It includes all new OEM Nissan components needed for installation, and all associated documentation. This clutch really needs no introduction, as it is certainly regarded as one of the best clutches available. Based on the Carbonetic website it will also work with the RB20 and the RB25, which would include anyone doing a rear wheel drive setup as well. As stated it is new in the original box and never fitted. Willing to ship at buyers expense, please contact me with any questions. Thank you
$2000 USD
Compatibility list
Compatibility identifies push and pull for BNR R32.
Is this correct ?
I have a late 92 BNR R32. So this kit is designed for pull with a push conversion? or is it the other way round ?
Edit: Sorry Just realised ad says USD so I take it your in the US. Never mind
Just wanted to update the thread with compatibility confirmation from Carbonetic. Open to offers
"Thank you, found the record.
PN ACN23210-14 - Nissan R34, BNR32(Koki, Late Model), BCNR33 - Twin 1350Kg
Matching list shows:
BNR32 YR 89.8-93.1(Zenki) RB26DETT 5MT Genuine MT
BNR32 YR 93.2-95.1(Koki) / BCNR33 YR 95.1-99.1 RB26DETT 5MT Genuine MT
R32 YR89.5-93.7 / R33 YR93.7-99.1 / R34 YR98.5-01.06 RB20DET / RB25DET 5MT
NOT for Hollinger, OS, HKS or Trust MT."
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
