So no where on the link inregards to safety gear do I see it read 1698:2006 and out of the 5 helmets we have at home 2 are under 2yrs old and only have 1698. Does that mean I can't use it? It is a open face with visor wore it to Lakeside Sprint day and officials said it's my face so I could use it.
The website say slow the 10.5 street car which i'm sure mine is says Approved Open Face Helmet – AS 1698 min
Just need to know this before I pay cause i'm not paying then rocking up and being told sorry wrong helmet you can't race today.
