Ey guys wrecking my s1 rb25det stagea it's a silver cor has teins all round spitfire coil packs twin sunroofs let me know what you guys need I'm located in melbourne east side car runs everything works 0401882730
https://www.sau.com.au/forums/topic/424995-wrecking-s1-awd-rb25det-stagea/
Yes cup holders under head unit
Has blitz return flow intercooler kit $300
Power fc with hand controller 900 obo
Front end side skirts tail lights coilovers gone
What are you after nick88?
Hey Jet2NV,
Tried to send you a PM, but it won't go through, can you PM me a price on the RB25DET (Turbo not included) and also the shaft from Transfer case to the front diff and a price on the rear diff also?
Sunroofs going tomorrow for 500 unless better offer motor has gone to someone else
Cooler kit is complete feel free to text me 0401882730
Also has spitfire coil packs 350
Ark electronic boost controller 200
What power FC did you have running this? For a 33 or 34 and what m wiring mods to make it work and was it still auto??? Only asking out of interest coz pfc don't normally match up to s1 loom or auto
