Hi all,
As post states my beloved R33 1995 GTS-T has been stolen from the front of my house in Fawkner. Pricks took it between 1-7 am I can't believe I didnt hear anything. Details of the car are as follows:
White 1995 R33 GTST coupe
17 inch P1 buddy clubs bronze colour
gtr front bar with bog patches on it, in the middle of being repaired. fmic
no spoiler, has duck wing on it.
sideskirts, right hand side skirt has sticker on it "tuned by dr drift"
tinted windows
car does stand out so again if spotted PLEASE post, contact police or me.
If anyone sees it around please contact Fawkner police 9355-6000 and ask for Const. Atherns or contact me via pm.
thanks guys.
https://www.sau.com.au/forums/topic/425150-r33-gts-t-stolen/
Hope you find it mate, mine was stolen about 6 weeks ago too, seems to be getting just worse an worse.
I'll keep my eye on drift sales and the like, a guy was attempting to sell a stolen car on there a couple of weeks ago so you never know.
Just over an hour after posting that we are now sitting on 1,242 people having seen that post. The more eyes out there keeping a look out, the better the chances somebody may spot it :)
Not sure about the other page, but no doubt a couple of thousand views from there as well.
Hope you get it back very soon!
First post mate, but I'm from the area and will keep an eye out for you. An often asked question, but did it have an alarm/immobilizer? I'd be interested in comparing the amount of thefts of these vehicles which don't have an alarm to those which do. It's dizzying the rate at which these cars are stolen.
Best of luck.
Colourclassic: Thanks mate we would appreciate it if you kept your eyes peeled :) Yeah it did have an immobilizer but installed years ago when I first got the car. So nothing flash oh and the steering wheel was locked which doesn't mean shit really as they can break that very easily too. But at the end of the day no amount of protection other than gps I think really safe guards you. If a pro wants your car I think unfortunately they win regardless :( I wish I could of caught them Id feed their balls to the dogs!
We've put it up on the Facebook page for you, fingers crossed you get it back soon!
Edit: Got it onto the Stolen Imports Australia page. Everybody will keep an eye out now :)
Will be adding this page! Thanks...... OP Sorry to hear, will be doing NSW to VIC trip in a week or so, will also keep eyes peeled!
Thanks 34gtt, remember rewards offered !
No reward needed for fellow SAU members :) Just hope you get your pride and joy back! I would be lost if it happened too me! Have you got any better pics of it to help?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
