Hello,
I am attempting to drop a GTX2863 in and i was wondering if anyone has tried this setup, or currently running it. Supporting mods will be Blitz SE FMIC, Nistune, Z32 AFM, 650cc injectors, fuel pump, 3-1/2" full jap exhaust, and a couple of other little computer bits and pieces. Stock internals, but healthy engine. I've been told around 250-290rwkw (maybe) on around 16 or so PSI, depending on tune. Before anyone asks why I'm not putting a GT3067 or something on, its because i want response, fast spool, and stock fitment. Also I can get one quite cheap, brand new installed for $1600 with everything needed to fit it.
Usually these turbos go great on a RB26 or something. Im sure one would run well, being rated for around 315rwkw.
Thanks anyone who has the time to reply, I appreciate your help.
John.
Edited by Roundcakes1
https://www.sau.com.au/forums/topic/425184-gtx2863-on-rb25det/
Hello,
They are not rated to 315rwkw, more like 315kw at the crank. There is no straight bolt-on version that I am aware of, you'd need an aftermarket/custom kit - be that including a modified/aftermarket housings or whatever. It will most likely require a reasonable amount of custom work.
I see, well I'm assuming he has the kit or modded housing that will go straight on. Apparently this guy has sold a couple of them. I think 315kw at the crank will still be around my goal power.
Anyways. Does it sound like too much work and money for only 315kw at the crank. I could just lash out, spend another couple of hundred and buy a GT3076, or GT-RS or something similar.
At least these are tested and proven. It sounds pretty sad to say, but I've seen some pretty good GT3076 deals with hose kits and gaskets, including new exhaust manifold for around the $2k mark. (I would prefer a low mount though)
Thanks for your help.
The GTX2863 is a tinny turbo. I don't believe they can pump 315rwkws.
I made a billet 64mm and 68mm comp wheel and used them in a customized one trim larger +2mm exd turbine based on the GT28 in a .86 rear and only managed to squeeze 276rwkws out of the 64mm and 298rwkws out of the 68mm. Those are E85 results on high mount externally gated setup.
My prediction on the GTX2863 is probably 230rwkws on pump 98 if used on stock manifold internally gated only if you run it on .86 rear. They will be red hot on .64.
i use a gt3076 with .63 rear. its very responsive. have no issues with it, standard manifold with mild porting, internal gate. using a apexi avcr boost controller as the small rear housing causes boost spikes. boost controller fixes this. i went from a gtrs to a 3076 and for the power difference (which dosnt feel like much, no dyno run as of yet) i wish i went for the .82 housing and sacrifice response over power.
point is get a 3076 with a small housing over the gtrs. thats my 2 cents. most people frown on a small housing gt3076r on a rb. best results will require WMI or E85 and external gate.
For what you would get from a GTX2863 on an RB25 I honestly believe you would be better off with a simple 2IU highflow from Hypergear.
User feedback on the 2IU is hard to overlook, some guys have used it for serious track and hillclimb duties to great success and response is what you would want it to be.
Its just too much effort to put on a 2863 with an unknown guinea pig rear housing when under $1,000 will have your stock turbo bolt back on LIKE STOCK and make the same 250rwkw mark with awesome response too.
You did a search didn't you..... ;)
lol no?
What am I missing?
If its re the 2IU results you know the HG thread is almost my second home, I don't miss anything there. If re 'mystery housing' I actually wasn't making any assumptions, but now that you have called on my mamories I do recall there being one for sale not that long ago, but I could swear it was a 2867 in a sonic housing.. Not 2863.
Feel free to fill me in though.
You are missing nothing it was a lame attempt at humour about searching this site to find answers to questions that have been asked several times. At least this thread has brought up a new turbo combo that we haven't seen results for yet. Nevertheless for 250rwkw-ish it is hard to go past a well made hiflow exactly like you said.
Haha damn man, sorry for being so slow. Was a good call now that I've been spoon fed some IQ.
Agree, it was a quick wind down but still will solve any questions if anyone did search 2863 RB25.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
