  • Replies 47
worth the risk? i think not!, the cops wouldnt know the difference if you had a gutted cat though!, but the exaust smells like the proverbial without a cat! and does it really make that much difference?
So bascially: if the cops see you have no cat (provided they know what they are looking for), you are in the deep end, and I think they can ether yellow you, or report you to the epa. If they see a cat (even hollowerd out), then you should be fine.
https://www.sau.com.au/forums/topic/42526-cat/#findComment-868839
why do you like having no cat?
because u like having flames out ur exhaust?
do you think it's really giving you heaps more power?
or you're being stingy and don't want to fork out for a high flow cat?
you know the exhaust fumes are heaps more toxic and poisonous without a cat, the smell stays in ur clothes, makes u sick and gives u headaches.
https://www.sau.com.au/forums/topic/42526-cat/#findComment-869648
tdawg if i see your car on a cruise I will write down your plate and get as much photo evidence as possible, and report you, there is nothing more im sure the epa would like than to make an example of someone
think about the environment for a change then the 1 or 2% power increase you get tool !
https://www.sau.com.au/forums/topic/42526-cat/#findComment-869945
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
