Hi guys, I have one of these exhaust manifolds for an RB26 exhaust port stud pattern . It is definitely turbo low mount and wastegate high mount. Roy is right (AGAIN?). :headspin:
See the threaded bumps sticking out of one side of the pimary pipes? They are for mounting the heat shield. The heat shield goes on the top and the turbo goes on the opposite side to them (note the split flange/pulse). Thus the turbo goes on the bottom. :cooldance
The round holed flange, on the top (same as the heat shield) is the wastegate mount. Mine has a 45 degree elbow mounted there and the wastegate mounts to the elbow. It clears an R32 GTR bonnet easily. :)
I strongly suggest you make up a heat shield (stainless steel is good) to mount to the manifold or get it ceramic coated inside and out. Ditto the wastegate pipes, wrap or ceramic coat. :)
These manifolds work very well, they have increased secondary pipe ID where the primary pipes join. Plus they keep the rear 3 cylinders separated from the front 3 until the turbine. If you have a split pulse turbo they work even better. :wassup:
Hope that helps
Darren, Get a custom 45degree elbow made when they do the mods to the dump pipe.
SK, getting in to those Smiley faces there. :)
Being the exhaust manifold is designed for the RB20 will the stocker RB20 exhaust manifold shield bolt up? May be close..
Cheers Sk :) May get back to you on how to rig up the heatshield. Or can u buy it from HKS?
Where did u get the 45deg elbow from incase i have probs fitting the wastegate??
The 45 degree elbow came with the manifold, but it is easy to make, any exhaust shop could do it. You can buy the wastegate flanges from any turbo shop already plasma cut, then the exhaust shop simply joins (welds) them up with a 45 degree mandrel bend. You use a HKS flange (pattern) for the manifold and you need to decide what wastegate you want, so you can get the right flange for it.
The heatshield is pretty much just a flat sheet of stainless steel with holes in it to line up with the threaded bumps.
Hope that helps
INASNT...are you running a high mount low mount as well. :)
Only because a manifold is cast doesnt mean its no good. Typically cast manifolds are superior to tubular, with the exception of the weight. A well designed cast manifold just like awell designed tubular manifold will work well, alternatively bad design is a bad design irrespective of casting or tubular
Roy is it true as well that due to it being cast, it retains in the heat from the exhaust well, helpling spool the turbo? It was mentioned to me that a tubular requires a few runs on the dyno to get a consistent reading ( to build the heat up) to tune....sound right??
Guest INASNT
I am running a custom made steam pipe high mount which is wrapped in that heat insulation.
My thinking is you dont want the exhaust to retain any heat (is gas transfers heat to manifold), you want all the heat (ie energy) to hit the exhaust wheel (turbine).
You want all the temp to stay in the exhaust gases. What he may have meant is that the cast manifold will safely operate at a higher temp without warping, cracking etc etc, and doesnt require bracing like a tubular manfifold.
I dont know if a cold manifold will give measurable power differences to a hot manifold, i think by the time the engines warm the manifold will be at its basic temperature...of course climbing when on boost doing repeated dyno pulls
It will handle high temperatures alot better, and with ceramic coating being so cheap, and doubling as a great means of protecting from corrosion then if i could get a well designed cast manifold, then i would quite happily use it.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
