I won't know for a few weeks as I've got a clutch to do, a cage to fit, a new seat mount to make, and a splitter to make and fit before I can get to the track =\
Keep tabs on my build thread though, I always talk results in there.
  • 2 months later...
  • Replies 41
What do people recommend for caster alignment for semis? Is it better to have more caster and less camber or the other way around? and how much is too much?
Thanks
yep more castor, less camber. Castor is dynamic camber so you get the benefits without the drawback on straight line traction.
you have too much caster when either:
* you cannot turn the steering wheel
* the wheel fits the guard or firewall
rightio, thanks duncan :)
getting an alignment next week, I think this should be ok
Front, -3deg camber, 1mm total toe out, 5deg castor
Rear, -1.5 camber, 1mm total toe in ( till i hit a bump, then 11ty camber and toe)
sounds like a reasonable start. I would go a little more camber in the GTR but I think your car is strut front end, right? I'd also go less toe at the rear but again it is different to gtr setup.
On the advice of other S13 drivers I ended up with almost -3 fron and -1.5 rear camber, and total 2mm toe out front and total 2mm toe in rear,
Castor I'm not sure, as much as I could get was the advice.
The toe will be interesting and may be finessed at the track.
Yep, mac strut.
Only issue with toe at the rear dan is my car has semi trailing arm irs, every time the suspension moves the alignment changes drastically. from static to full bump is something like .5mm to 12mm a side. same with camber
Don't worry, you'll go faster than me anyway, toe will make no difference when the driver is a ham sandwich (me).
:D
Would you try doing the alignment yourself? as that was why I started this thread.
Get onto Stew Wilkins, he's been playing with 1600s and Z cars for a long time, should have some gear and know how.
http://www.swmotorsport.com.au/index.php
  • 9 months later...
thought id bump this thread up again. :)
i now have a r32/33 multilink rear setup in my car, what alignment do people recommend for them? im using A050s at the moment
No idea from me, but I can bump this also and say that my car handled quite well in my opinion at the logic day I did, it felt nice and direct.
It seemed to air on the id of understeer at the limit in a faster speed sweeper which I think is roughly how you want it anyway?
I wouldn't mind it to be a touch more neutral so I'm assuming a little less front camber or a little firmer in the rear?
James I reckon the big trick is to install adjustable upper links in that rear end. That will allow you to get the camber setting you want, and most importantly, to dial out bump steer from big toe changes as it moves through its travel. Dynamic change is what can make them a handful, as you'd know with the old semi trailing arms.
I'd imagine yours will not be using a whole heap of travel so it's going to be easier to dial things in. It should be possible to get minimal toe change if you're using 50mm of bump and similar for droop.
Static settings, I'd think the 1 - 1.5 neg camber and 1 - 2mm toe in per side. Run it and go from there.
Thanks man. It's had adjustable gear in so it so that won't be a problem. Yeah, the old semi trailing irs is/was quite a handful. Hoping even with some bump Steer the new setup will be a massive improvement.
I had it aligned today. Went with -1.5 camber as you suggested but dialed it back to 0.7mm toe in a side. Rear Toe is used mainly for stability is it not? If I need I can adjust it at the track.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
