Carbon Fibre Or Fibre Glass Parts 180Sx,s15,r32,r33,r34,r35,evo
Hi TS, just to share that you may need some modification as the items are not direct replacement. I bought the items before: R34 GTR CF Spoiler, R34 High spoiler leg, R34 Eyelids, R34 Door sills. Am only using the high spoiler leg now. Considering to get the rear bumper diffuser cover :)
I have confirmed with the supplier only some items will need minor DIY, Most are direct fit and would be no problems :)
All supplier's have different molds and designs for there product.
Longz : R34 GTR Nismo Side skirts , Rear pods , Canards, exhaust shroud cooling panel and rear diffuser, EVO side skirts, canards, rear exhaust shroud
haz_jaz : skirts/pods and CF Wing blade for R34 GTR
Terry_GT-R34 : EVO Skirt Add-ons , Radiator Cooling Panel, Rear Boot Spoiler Lip
jase_c : R34 Gtt radiator cooling panel
DeaN20 : R32 GTR radiator cooling panel
Charles89 : R34 GTT CF radiator cooling panel
Sinno: Evo rear diffuser and canards.
Some guy: 350z lip + skirts
joelsy777 : R33 hood bonnet lip.60mm Pillar gauge cover,B Pillar cover, Centre console arm rest
DJRIFT : Carbon mirror cover r34gtt, R34 weather shields r32 lh headlight
YE34OK: Carbon: wing blade, exhaust shroud, wind deflectors *UPDATED*
gtsttrk:R33 Bee R wing
Coldfusion : R32 headlight intake,R32 FRP eyelids
tomo : R34 cooling panel, R34 mirror covers, R34 GTT carbon boot
OON80 : R34 GTT canards
Yeedogga : r33 cf boot
riseofbrutality : r34 gtt cooling panel
Just bought a carbon boot and mirrors, update my order to carbon cooling panel. Cheers
Edited by tomo123
tomo: yeh FRP is available
No worries, can I update my order to R34 GTT carbon cooling panel and FRP R34 GTR JUN High wing stands
Has this company been bought from before?
Has anyone had any quality issues? Or Fitment issues?
What is the over all quality like etc etc?
tomo : R34 GTT carbon cooling panel and FRP R34 GTR JUN High wing stands
Just an update seems like the supplier only does Carbon Fibre High wing stands no FRP sorry !
adz: yes items have been bought before such as high wing stands etc. There was no DIY required however as advised by the supplier some items will require minor DIY
I really appreciate what you are doing here, I mean that.
But I'm not sure whats happened here:
Hey mate,
Do the R33 B-pillar covers replace the original ones or just cover the original ones?
If not I might be keen on an R33 GTR wing blade
Did you hear back about the B-pillar covers?
I'm in for an R33 GTR OEM wing blade either way. Let me know about the B-Pillars then I'll decide on them
To easy
Thanks mate
Can you put me down for an R33 GTR OEM wing blade?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
