Another update:
Slowly getting things done, almost ready to put the head back on.
Cleaned the surface of the block.
Also spent quite a bit of time getting the head gasket as clean as possible. Just needs a coat of hylomar and is ready to go back in.
Before
After
Layed down a coat of VHT. Unfortunately it's TERRIBLE weather to be spraying but meh, the quality is not that important. As long as it's not blue!
Edited by RB2600
More progress today, exams are approaching so it really should be time to get studying :whistling:
Installed the new water pump
Wrinkled the lower timing belt cover, just to prove to myself that lighter coats would work better. I didn't spend alot of time on prepping this item so some bits of paint was left over
which you can see in this photo, but obviously once it's on the car, it's a different story.
And it's finally starting to look a little more like an engine again!
Nice progress mate :thumbsup:
BTW what are u studying?
Had the weekend to do uni work, that was enough....
Had a very productive day, have the head back on and it's again closer to being a complete engine.
Will let the pictures do the talking
And the work continues tomorrow
It does look cleaner without, but it is there for a reason. Did you have the head shaved/skimmed at all? Or at the very least, clean it up with an oil stone? I'm just asking because the block and head surfaces need to be flat, especially when using a MLS head gasket.
Cleaned the head as best I could and checked for straightness as per manual instructions.
I do hear that MLS gaskets require a finer RA but this head looks pretty virgin. So it makes me wonder how it's been ok with the gasket that's in it thus far.
That and I've sprayed hylomar on both sides of the gasket. I'm hoping it will do the trick :)
Considering keeping the front cover off!
Compared to
Gives it more of a rough feel, yes, no?
although I agree with you that it looks tougher I am pretty certain it would give you a defect for not having the cam gears covered.
get a clear timing or by my VHT one ;)
  • Like 1
Hey mate, i'm sure someone would back me up on this but i've learnt not to put hylomar on gasket material as it has a tendancy to shrink increasing your chance of leaking gasket, it is only good for metal on metal surfaces like decomp shims. best off spending the money getting head faced, should be between 50 to 100 bucks which is cheap in my opinion rather than having to strip it down and do a head gasket again
Why not get a Greddy clear belt cover, best of both worlds! Would suck to drop a bolt down there once it's back in the car. Nice build btw!
Very true about bolt falling down! Thanks man, did not think about that at all lol
Cover on it is!
Yeah I've decided cover on, will spray the covers closer to summer time :)
Hrmm, I have also heard alot of success stories with hylomar. A tuner has sprayed his a few times with no problems.
If it's good enough for him it's good enough for me. But thanks for the heads up, if I do have a whinge about it here you
can laugh at me and say I told you so :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
