Another update:
Slowly getting things done, almost ready to put the head back on.
Cleaned the surface of the block.
Also spent quite a bit of time getting the head gasket as clean as possible. Just needs a coat of hylomar and is ready to go back in.
Before
After
Layed down a coat of VHT. Unfortunately it's TERRIBLE weather to be spraying but meh, the quality is not that important. As long as it's not blue!
Edited by RB2600
More progress today, exams are approaching so it really should be time to get studying :whistling:
Installed the new water pump
Wrinkled the lower timing belt cover, just to prove to myself that lighter coats would work better. I didn't spend alot of time on prepping this item so some bits of paint was left over
which you can see in this photo, but obviously once it's on the car, it's a different story.
And it's finally starting to look a little more like an engine again!
Nice progress mate :thumbsup:
BTW what are u studying?
Had the weekend to do uni work, that was enough....
Had a very productive day, have the head back on and it's again closer to being a complete engine.
Will let the pictures do the talking
And the work continues tomorrow
It does look cleaner without, but it is there for a reason. Did you have the head shaved/skimmed at all? Or at the very least, clean it up with an oil stone? I'm just asking because the block and head surfaces need to be flat, especially when using a MLS head gasket.
Cleaned the head as best I could and checked for straightness as per manual instructions.
I do hear that MLS gaskets require a finer RA but this head looks pretty virgin. So it makes me wonder how it's been ok with the gasket that's in it thus far.
That and I've sprayed hylomar on both sides of the gasket. I'm hoping it will do the trick :)
Considering keeping the front cover off!
Compared to
Gives it more of a rough feel, yes, no?
although I agree with you that it looks tougher I am pretty certain it would give you a defect for not having the cam gears covered.
get a clear timing or by my VHT one ;)
  • Like 1
Hey mate, i'm sure someone would back me up on this but i've learnt not to put hylomar on gasket material as it has a tendancy to shrink increasing your chance of leaking gasket, it is only good for metal on metal surfaces like decomp shims. best off spending the money getting head faced, should be between 50 to 100 bucks which is cheap in my opinion rather than having to strip it down and do a head gasket again
Why not get a Greddy clear belt cover, best of both worlds! Would suck to drop a bolt down there once it's back in the car. Nice build btw!
Very true about bolt falling down! Thanks man, did not think about that at all lol
Cover on it is!
Yeah I've decided cover on, will spray the covers closer to summer time :)
Hrmm, I have also heard alot of success stories with hylomar. A tuner has sprayed his a few times with no problems.
If it's good enough for him it's good enough for me. But thanks for the heads up, if I do have a whinge about it here you
can laugh at me and say I told you so :)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
