Well now I'm screwed still exactly the same and even Andy from adaptronic has no idea. Tried new coils , plugs, injectors, cams , checked compression, checked cam gears checked all new joins as in ballast resister and injectors , I really don't know what else to do? I love this car and it means alot to me sentimentally but my brain can't take this , I don't think I can pull it out and start again financially or physically
  • Replies 60
Fuel delivery pressure and Fuel quality ?
Actuators ok ? (misfires @ 9psi consistently )
what's the RPM when it misfires and how bad is it? Can you go passed it ?
Any anomalies in the ECU data logging
Summarising change overs, anything else ?
ECU X 2
Injectors x 2
Plugs x 2
CAS x 2 ? + adjusted dwell
Coil packs x 2
Coil Pack harness (new)
Ignitor x 2
Earthing x 2
CAMS replaced to stock
Cam gears
You maybe right - something under pressure within the head/block (Mechanical).
All the external gear seems double checked :(
Edited by Sinista32
As its still at dyno I havnt been as to drive it myself, from 9-11 psi I'm told , only under load so my plan is to get jez to try a nisstune see how that goes failing that do a safe tune so I can get ur home. I'm thinking leak down test first as comp test was perfect , next put 15psi into cooler piping and check each port with inlet valves closed for leaks, possible injector seal issue maybe pushing out under boost as they are not factory seals and are a little small for manifold compared to stock. Next is create a daisy chain from each coil to earth and possibly a relay and direct power from battery. Failing that run new jumper wires from ecu direct to each coil. Triple check injector wires and ballast wire joins. Lastly strip harness rig up a buzzer to each injector wire and sensor wire and somehow apply 12 v at ecu end and listen while moving harness for any changes that may indicate slightly broken wire. It's got me stuffed though it sounds perfect and passes every test except when boost is applied, I really don't want to strip engine down and jez doubts its internal , oil pressure is perfect as is temperature he said slight bubbling in rad after run on dyno but is normal I'm his experience.
Other than that sell it on and give someone a bargain but I met my wife in this car so it's very sentimental but with my mental health at stake I can't take much more
Its got to be electrical. Can't be mechanical man.
has jez tried just flat out doubling the dwell? Dwell is hard to work out what's best at times.
failing that what are the AFs doing under boost when it cuts? Does it chop and change or is it consistent?
If the AFs are all over the shop when boost starts to come on you better look into all things related.. Try smoke test it at 15-20psi and try a different set of injectors.
To me its either going to be an intake leak which is very close to the ports/injectors or its going to be a fuel control issue. So maybe injector seals giving out, FPR or pump failing under load or injectors failing under equalized pressure.
Time to start fiddling with the above.
The only thing that isn't new is the nismo fpr, mmm I wonder and I'm a little concerned about seals pushing out under boost even though they are new , intake gaskets are nitto metal which I sprayed hilomar and torqued to spec and have never had issue with these on the last two engines, it turns out stock ecu isn't wasted spark I wonder if that's a possibility?
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
