Hi everyone...
Does anyone know if the Tokyo Autosalon dates for 2014 have been released yet? Might be going up with a small group of people and would like to book flights soon as we know the dates as prices get pretty high the longer you leave them
Is anyone else planning to go up?
https://www.sau.com.au/forums/topic/426121-tokyo-autosalon-2014/
Ok lol thanks for all your help? If anyone finds out dates please post up :)
Btw havnt been on here for years.. Is SAU dying down? Iv noticed not as many ppl use it anymore.. And if this the thread had carried on about off the topic stuff years ago the mods would delete the posts or make some kind of comment about taking it to the wasteland.
not dying down, as such. just has more trolls. we've captured the mods. We are slowly brainwashing them to become like us.
this is what generally happens when not much good information is provided in a thread. we are merely helping you keep the thread at the top so that when someone with useful information comes along they will see the thread and have an input.
theres a positive insight to everything.
SAU = less people, more posts. Still very alive and kicking. Also...what Sunkist said.
Oh, you think SAU is your ally, but you merely adopted the forum. I was born in it, molded by it. I didnt see the topic until I was already a man. By then, it was nothing to me but off-topic! The trolls betray you, because they belong to me!
  • Like 1
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
