  • Replies 269
Hi all,
I have received all the parts i need to make another batch today, and will start taking orders. If you would like one, pls contact me with your contact details.
If you would like more info, reply here!
Impakt
Couple more questions, thought this'd be a better spot for it, share the info. and avoid clogging your PM inbox Impakt.
1. What are physical dimensions of the screen?
2. How difficult would it be, for some one with moderate skills, to solder a ribbon cable between the box and screen (say ~30cm length)?
2a. Would the above detrimentally effect the units operation?
The above comes about from the desire to mount the screen in a small space necessitating it's detachment from the box.
3. What's the feasibility of having the display all come up backwards, mirrored, so it could be placed on the dash and used as a Heads-Up-Display?
A switch to choose between Normal/Mirror would be IDEAL!
4. How would, or could, you go about dicking with the speed signal? I ask because i have an auto diff (4.3:1) in a manual car (normally 4.11:1 diff) so my speedo is out, this way i could have an accurate reading.
Good questions Oosh,
1. The physical dimensions of the screen (PCB) is 98mmx60mmx~15mm. THe actual LCD part is smaller.
2. To remotely mount the LCD is not that hard, as long as you know what you are doing. Im happy to sell a display with the LCD and case seperate, so you can mount as you wish. Its 12 wires between the LCD and PCB, so a decent ribbon cable should do the trick. I would recommend you letting me know if you want to remote mount the LCD, that way i wont solder it on in the first place (and create extra work for you).
2a. Won't affect operation at all, just shield the ribbon cable to reduce noise.
3. A super bright VFD or LED module could be used for HUD. LCD will never be bright enough to be used as a HUD.
4. Not possible without re-programming the device, which im happy to do (at a small cost). Just tell me how much you need it tweaked by, and i'll write the code to do it.
Impakt
snip .... /snip
Impakt
Thanks for your answers, if you COULD leave my LCD unattached, i think i will give this a go but please include the wires you would use just in case i decide to go back to stock.
As for speed, it'd need to be altered by a factor of 0.95, i.e. display 95kmh when it's detecting it as 100kmh.
Some further questions:
1. Just how small a fee? :thumbsup:
2. Could i keep the original speed variable? i.e. have a Speed1 and Speed2 var.
3. Will either option (modified or 2 vars) effect compatibility with any of the softwares esp. data loggers?
Cheers.
Found this case at Prime Electronics here in Bridbane.
Did a quick transplant and used some smaller push buttons. Guess I just can't help dicking around with things...
is that a laptop hard drive caddy?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
