Hi all
probably asked a lot of times already...but just wondering what are your thoughts on it...
if money wasnt really an issue( i wish :rolleyes: ) which would you choose? a V spec 2 nur or a R35
for me.. I've sat in a BNR34 with a HKS RB28 and the R35... no doubt the R35 is really comfy and fast, it just doesnt cut it...for me. I'd pick a BNR34 anytime :wub:
https://www.sau.com.au/forums/topic/426173-bnr34-or-r35/
the 35 is no doubt a crazy fast car, but ive always loved the bnr34 the most since i was a kid, so thats my choice, in bayside blue, or black :D
same here.... except for the kid part.. :whistling: but after seeing the millennium jade color... i have to say it grows on u..
Bnr34. Don't like cars that are overly electronic. Kenmeri any day of the week though. :)
me too... that said... if anything fails...it'll be a bitch to troubleshoot
I'd have a beast as 34...
In saying that if money wasnt an option that 34 would have some form of twin turbed LS in it
after reading some of your posts.... i was kinda expecting u to say that... HAHAHAHAHAHAH
*mother of all facepalms*
i know!!! *faints*
Edited by C4a0s
https://www.sau.com.au/forums/topic/426173-bnr34-or-r35/#findComment-6873313
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
