Arrived couple days ago from brad profab for our dry sump set up. Also Bc picked up a pump elsewhere which saved us heaps of cash, Brett and dean have heaps of contacts in the Motorsport industry so we are lucky or else this new build would honestly not be possible.
Now some new aero and spray job required, so off to Andrew Kinsmore, Kinzy paint and panel to attach our new side skirts, spray up the interior and engine bay. Decided to match it all in same colour. Our old n1 side skirts I thought looked awesome, always loved them but to much air was getting under the car and causing lift, so added these which dropped the 220mm front and 240mm rear gap down to 100mm, open class allows ride hight at 65mm, we can perhaps lower it a little more, there will be a full flat floor after time attack which will get the hight down.
Mate that thing is a rig 470kw is leathal on the track you aiming for more power with precision turbo?
Our weakest link will be the block I believe, 450-500 should be fine for time attack, if we run 470 plus for a lap or 2 then we will pull the engine apart for a refresh after the event. The biggest advantage over the new engine turbo set up is when the power delivery will kick in and the higher rev range, as prior we didn't exceed 8200 I believe from memory.
Fitting up the front canards. Wool tuff test to see how the air flowed around the skirts, and to position the canards correctly. If only I had another 100k to spend on aero...then we could try pro class. I really appreciate when I see teams going flat out with aero as it makes a huge difference, but running pro class these days comes down to cash.
One of many tests performed at Bc automotive.
www.youtube.com/watch?v=Hi3Ym22ruog
Our new goal lap time for Phillip Island is 1.31, we believe this will equate to around 1.29-1.30 at Sydney Motorsport. Going by the Gt series cars and deans experience there's about 2 seconds difference in the track if set up correctly. I will post more as work progresses, if you would like to follow the build on Facebook or through Bc automotive the links are below. The build will be complete by July 7th latest to get back for more testing at the island.
Hope the links work,
https://www.facebook.com/BCAUTO
http://www.bcautomotive.com.au/
Good to see it coming along.
The touring car guys used that wool test in years gone by as well.
The interesting part when fitting up the side skirts in front of the rear tyre the air would stall(wool tuft would just fall), so we pulled the side skirts out just a little in line with the wheel and it would flow perfect without the tufts stalling. So we will fit it up like this and painted by Tuesday. Thanks heaps for your work on the oil pan, speedy return and great work.
Excited.
Any idea how many Victorian cars are competing? Congrats on club class dude, will be a fun few days. I've noticed Wtac aren't posting all competitors as most cars aren't ready yet, and they are building up the hype.
While I'm waiting for the painting, thought I'd share some other work that has been carried out by dean and Brett over the years.
Ap racing front and rear brakes, with brake bias adjustment. These were a massive step up in stopping performance from the csc brakes in the past. Also repositioned the oil cooler to the side vent which solved the engine oil temp getting hot after even 2 laps in the past.
Dean made up an aircraft aluminium stainless steel side exhaust which you can pick up with 2 fingers. Eliminating the old full length exhaust saving around 12 kg. Needs to be modified to fit through the new side skirts.
Exhaust looks awesome, sorry I must be confused with the material.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
