Just wondering what you guys think i should do with these 19x10.5 LMGT4s I just bought.
Was thinking of getting them painted 'Nismo Black' to match my 18 x 9.5 Omori set, but on the other hand I'm thinking it would be a shame to paint over the factory silver with polished lip finish.
Will be going on a Bayside Blue BNR34 by the way.
Thoughts?
Edited by PAV34
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/
I'd leave them silver personally (with your BsB body).
A Nismo Black Omori set later on for the track will make a great contrast.
I have 2 sets of LMGT4s both in Nismo Black (powdercoat) - but that's because my car is QM1 white and they were both 2nd hand with slight imperfections.
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6874398
Very nice, was watching these even though I don't have anything to put them on! Went for a decent price too, congrats!
Another vote for leave them silver, will look excellent against the bsb. Only tip would be to change centre caps, go the flat caps in the diamond cut finish as per my sig. Jesse streeter sorted mine for a good price
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6875633
They went for an OK price, but when you add, delivery, commission, etc it ended up costing me more than a new set would.
They look great in your sig, i think those centre caps are definitely the way to go.
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6875644
Yea but I was told the LMGT4 were semi discontinued (need decnt number of orders before Rays will make them). And to make things harder, 10.5 are typically a made to order size and even for TE37, they can take awhile since its not off the shelf (typically). Good pick up I'd say.
ps: if you've seen my other post, you might want to check how much a new set will cost as I've notice Rays for whatever reason decided to jack up their already very exp rims by another 50%+ (something like 2yrs ago was 52,000yen and now 82,000yen, TE37 18x9.5).
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6875657
No idea. This was 2yrs ago when I got the 18x9.5 TE37. I was actually after 18x10.5 TE37 or LMGT4 but the TE37 needed a couple of months (which I didnt want to wait) and LMGT4 doesnt even have an ETA date (even 9.5). Which is why I end up with these TE37 now.
Cost shouldnt be all that hard because what I get quoted is basically what is listed on Ray's website. Just check that and convert to AUD + frieght + agent commission and it should be it. I paid 3.2k for mine when it was 52,000yen (1aud = 75yen?)back then so you can kinda work backwards and see how much the frieght and commission is. 10.5's gonna be slight more expensive too.
Easier, email Streeter or similiar exporter to get an actual figure.
Define decent number Brandon.
10 sets?
I'm sure these forums could get 10 people interested in a 19x10.5 +12 set of lmgt4s.
Depending on retail price at the moment, it would even be easy.
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6875943
Lmgt4s can be made, 10 sets is the min order ,and they come in 4 colours offset 12 and 22 ,I looked at doing this about 1 year ago through the guy that imported my car for me,but it was 4800 for bronze black silver ,I think white was slightly dearer.
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6875993
  • 1 month later...
Nice mate. I don't usually like 19s on a GTR but you have changed my opinion. Suits the car to a tee. Perfect. Congrats
Yeah i used to have that same opinion on the 19's, but for the street and depending on the wheel type, i think they can look quite nice
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6928145
The photos were taken from yarra blvd I believe. Nice little bit of twisty action. Not the best for the 34 gtr but nevertheless lots of fun if you're bored :)
Those rims are the best for any 34 gtr. Hard to source so I went with TE37's
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6928259
Just perfect, no repaint required.
Leave as is.
Plus, keep them in original and minty condition and they will only appreciate in value.
PM me if you want to know where to get a set of unbeatable lock nuts.
https://www.sau.com.au/forums/topic/426237-19-x-105-lmgt4s/#findComment-6928286
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
