Nsw: Wtb Rb25Det R33 Harmonic Balancer (Desperate)
I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
