I just sold my Skyline one month ago and the owner has been away working and when he tried starting it the car it started than died. It wouldn't start at all after woulds and he flattened the battery twice trying to get it going. He got the vehicle towed to a mechanics and they have told him the car has no compression??? WTF could this be caused from washing the bores? Car ran fine and never blew smoke apart from being too rich at start up and idle it had no other issues
https://www.sau.com.au/forums/topic/426316-car-sat-for-a-month-wont-start/
Bore wash increases wear to the bore so yes a loss of compression can happen
Sounds like the "Mechanic" doesn't know shit from sugar or he's trying one on.
Buyer drives it home, parks it, doesn't do anything else, a month later tries to start it to no avail.
- Replace Plugs ($25) n Battery ($150) with new. Try start it.
If indeed the compression is low (no compression - pfffft) it was farked before sold.
IMHO anyway.
IMHO anyway.
The mechanic doesn't know shit? but yet yet your giving him advice to spend 175$ on parts which may only turn out to be a further kick in the guts
Is this an RB20 or 25 at all? Sounds like the hydraulic lifters may have bled down due to sitting for too long. Just keep cranking, for no more than about 20secs at a time without letting the starter cool.
This is a easy
While he was away couple of hes pissed mates thought it was a great idea to take the skyline for a rap to Maccas to get a $2 cheeseburger or two
Nek Minit
Pushing it back where they got it from
  • Like 1
Are you certain the guy was actually away working? Maybe he is lying and just raped the car for a month and then it died. Either way, it's got nothing to do with you. As long as it was running when he drove away then anything that happens after that is his problem.
  • Like 1
Well said.
Simply put Yes I am. I believe the money is not wasted spent on these items. Not by the seller but by the buyer.
Cheaper option - clean existing plugs, swap in a battery from a mate and crank away....
-> Skyline works fine, not driven for a month, no compression - Some one is lying !!
If I didn't drive my GTR for a month. And then killed the battery twice trying to start it then I would do exactly what I advised.
My plugs will be fouled and my battery is likely also cactus. My compression would be 165-170 not 0psi
  • Like 1
Maybe check the compression yourself to make sure, I can remember a similar thing with an r31 my bro owned, it ended up being a cracked cylinder head....
Edited by AngryRBGTX
so much this.
no compression?
so, not 1 cylinder has an ounce of pressure?
I find it very hard to believe.
maybe no fuel pressure?
in which case, fuel pump.
and it wouldn't start.
do the usual.
test fuel, test spark, actual comp test(with vid results), and go from there
  • 1 month later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
