What Is 'too Much' Power For The Street?
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I once knew a woman who had a v6 commodore and said it had to much power and traded it for a outlander because it was only a 4 cylinder
i once knew a woman with a v6 commodore, it slid out around a corner in the wet so she took it to get her traction control checked :huh:
34geteetee makes 391rwkw on 28PSI, whereas not only is Scotty's stagea running 4PSI more, but makes 50rwkw less despite running the equivalent turbo and displacement (2.5 6 pot)
Sometimes its not about displacement or cylinders, but more so engine design, the RB2.5 motor is certainly capable of huge numbers with head work and a built motor, but once again irrelevant for street use
didnt say it wasnt possible, just said its not easy...
I don't have a built motor or head work? Actually I don't even have an aftermarket headgasket so u fail to see how they contribute to big numbers?
even bigger numbers with head work and a built motor, your motor will never make as much as a rb26 without the head work and possibly a stroker
http://www.skylinesaustralia.com/forums/topic/426942-lewis-engines-rb25neo-head-vs-there-rb26-head/
It has an extra 100cc advantage, thats it!
Yes my engine is stock, and the stock cams would be holding me back big time at 8k, but the power loss of the auto is the big reason for less output. (not to mention the awd losses) You can really only compare the same cars on the same dyno imo.
Dyno's don't tell the big story, my car has monstrous torque and has given many a Racepace GTR a run down the straight at Sandown, even though it weighs over 400kg more. The V6 trades power for torque similar to V8's I think.
:yes: a lot more to the story that just a dyno figure...
70cc u mean in the form of a stroker for extra torque. And stock heads the rb26 flows more and has the better 6 throttle body intake, but with porting that's a different story.
^ I don't know any RB25s that make 963awkw like this r34 GTR
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
