I've got a set of Racepace adjustable cam gears from an old motor, that I would like to install into my new engine and they've been dialed in for the previous setup.
My question is whether or not it will be fine to install as per normal? I.E. take stock gears off, bolt adjustable gears on, line up dots on cam gears to timing cover back plate, line up timing pulley to oil pump mark
and install timing belt and idler and tensioner as per usual. Or will installing this way cause me to be a tooth (or more) out / screw up the timing?
Pics to show where the cam gears are currently adjusted to
I also have the head currently off and taking the stock cam gears off caused a slight ANTI-CLOCKWISE movement. I've been told to check the alignment ONLY from CLOCKWISE rotation.
Would it matter if I just aligned the cam gear timing marks regardless of rotation direction, considering the head is off at the moment?
Finally, I will be heading to the tuner ASAP after I have the car up and running, it will only be light driving to get it rwc'ed, registered and next destination would be the tuner's workshop.
Thanks in advance
https://www.sau.com.au/forums/topic/426490-adjustable-cam-gears/
Everything is keyed to fit in only one way. If all the marks are lined up on the cams and your crank is lined up then everything will be lined up. If the head is already off just line it up before you slap it back on. I cant really understand what you are trying to say in regard to the clockwise anti clockwise but if you took the belt off and fudged a cam by turning it, you can't turn that cam all the way around to line it up. I'd say it should be fine just to dial it back a couple mm which ever way you need to go. Dont hold me to this but I think its right.
do you have to move everything to TDC and stuff before removing old gears or can you just remove them and line up dots?
You can just remove and replace but if you are at tdc you will know exactly where you are and if something moved you will know exactly where you should be. I really wouldn't do it if you arent at tdc. Think about it if you turn your cam gear even 1 degree how are you going to know?
Head off you can turn the cam freely. Head on just turn it back or forward to the dot not all the way around.
If I was at your place, then I would like to start from zero, as this is required by the engine also. If you don't do this, there cause a problem. Which can be increase with the passage of time. Which can cause cease the engine. Also, when you finished your change then don't forget to fill the new and quality one oil which keeps protection.
Head on or off rotating camshafts individually out of rotational sequence will and can cause inlet valves to touch exhaust valves as they are never open anymore than .100" at the same time in operation. The valve angle allows the valves to clip one another causing the ground seating face of the valve to be damaged
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
