I've got a set of Racepace adjustable cam gears from an old motor, that I would like to install into my new engine and they've been dialed in for the previous setup.
My question is whether or not it will be fine to install as per normal? I.E. take stock gears off, bolt adjustable gears on, line up dots on cam gears to timing cover back plate, line up timing pulley to oil pump mark
and install timing belt and idler and tensioner as per usual. Or will installing this way cause me to be a tooth (or more) out / screw up the timing?
Pics to show where the cam gears are currently adjusted to
I also have the head currently off and taking the stock cam gears off caused a slight ANTI-CLOCKWISE movement. I've been told to check the alignment ONLY from CLOCKWISE rotation.
Would it matter if I just aligned the cam gear timing marks regardless of rotation direction, considering the head is off at the moment?
Finally, I will be heading to the tuner ASAP after I have the car up and running, it will only be light driving to get it rwc'ed, registered and next destination would be the tuner's workshop.
Thanks in advance
https://www.sau.com.au/forums/topic/426490-adjustable-cam-gears/
Everything is keyed to fit in only one way. If all the marks are lined up on the cams and your crank is lined up then everything will be lined up. If the head is already off just line it up before you slap it back on. I cant really understand what you are trying to say in regard to the clockwise anti clockwise but if you took the belt off and fudged a cam by turning it, you can't turn that cam all the way around to line it up. I'd say it should be fine just to dial it back a couple mm which ever way you need to go. Dont hold me to this but I think its right.
do you have to move everything to TDC and stuff before removing old gears or can you just remove them and line up dots?
You can just remove and replace but if you are at tdc you will know exactly where you are and if something moved you will know exactly where you should be. I really wouldn't do it if you arent at tdc. Think about it if you turn your cam gear even 1 degree how are you going to know?
Head off you can turn the cam freely. Head on just turn it back or forward to the dot not all the way around.
If I was at your place, then I would like to start from zero, as this is required by the engine also. If you don't do this, there cause a problem. Which can be increase with the passage of time. Which can cause cease the engine. Also, when you finished your change then don't forget to fill the new and quality one oil which keeps protection.
Head on or off rotating camshafts individually out of rotational sequence will and can cause inlet valves to touch exhaust valves as they are never open anymore than .100" at the same time in operation. The valve angle allows the valves to clip one another causing the ground seating face of the valve to be damaged
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
