Gday Fellas,
Im relatively new to the forums. I have always been a lurker. Sitting in the shadows watching other people build things and then hopefully implementing them on my own car.
It all started in early 2012 where i finally decided to bite the bullet and visit Mastercars Blacktown to purchase my very own r34 gtt. I fell in love with the red r34 they had sitting there for the last month and I knew i had to have it.
After a little bit of haggling here and there I ended up buying this:
It was a clean example with a factory sunroof.
The only aftermarket parts were:
18" rozza wheels
blitz turbo timer
hks hiper max d coilovers
Im not really looking to build a track car. Just something clean and streetable that packs a punch. let the modding begin
https://www.sau.com.au/forums/topic/426655-the-red-lady-sandybangs-r34-gtt/
Everything was looking great at this point.
Here is my engine bay:
I got all the fluids (clutch, diff, oil, coolant etc) all drained and replaced.
I soon realised that i needed to get my brakes done.
So i went from this:
To this:
And i always wanted a bit of woosh so i ordered this from nengun:
and just to keep it somewhat legalish i got this from hi octane motorsport:
Now in order to prepare my car for better flow I was on the hunt for a decent exhaust system. I ended up with a nismo turbo back exhaust (including genuine nismo hi flow cat) that i got for a bargain!!! Such a sweet note on the car when you open it up and none of that annoying drone. And it looks kind of stockish.. not really.
And to further improve my flow I purchased and installed a black series kkr intercooler from otomoto. Does not have the same flow as say a blitz or a hpi but i am quite impressed for $400 brand new with piping. And it didnt require much cutting at all
Finished product:
Also changed the parkers to smd leds:
Edited by Therealsandybang
I ended up buying 19" starcorps for some fat fitment. They started off being like this:
To this:
On the car they looked like this:
But i was never really happy with them. It was way too bumpy and the wheels felt heavy. I ended up going back to my trusty rozzas
I also decided to remove my old clutch and get a new custom exedy single plate organic clutch kit from western clutches:
old:
new:
It was a bit heavy for the first 700km but now is quite nice.
Got some new gauges. Not sure if too ricey?
First I went and bought some supplies :
The rb26 bov has a larger pipe so instead of using an adapter I used the original factory pipe inside the new radiator pipe as a collar. I sealed the space between them with gasket sealer.
I was originally going to use a rubber gasket glue to attach the rb26 bov. It appears that the gasket from factory is a much better option if it is in good condition.
There was a bit of dirt And grime on it so I sanded it lightly before:
After:
Here is a comparison. Left is the neo and right is the gtr
Before:
After:
I also replaced the heat shielding stuff.
And after all this I still get the fart noise.
Lol oh well
I've just gotten my drainage sill things painted under the hood and in the boot. You can tell in my previous pod box image that the sills were faded and slightly rusting.
Same story in the boot.
I've got a nice clip on rear camera kit from carbon car systems. It's a factory looking fit.
I also hardwired a dash cam and hid the wires.
This is a pic of my universal washer bottle and pump fitment. I got it in the factory position. Yeah!!
Repainted the rozzas a grey carbon with gold flecks
And some door protectors. I know it's granny spec but it protects my doors lol
There was a cleaner factory option in s2 33s which icouldnt find for a 34
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
