Yeap. I'm just looking at coilpacks, fuel pump and maybe a short shift kit too. Just reading on the forums at the moment for some more information and recommendations.
Plenty of info on here, if you get stuck just ask one of us and we will be happy to help....
Splitfire coilpacks are tried and tested, fuel pump choice depends on your goals etc and as for the shifter kit, i have the Nismo but i dont believe its much shorter..... Good shift feel tho :)
Oh, if you want to join SAU NSW too, there is some info in this thread -
http://www.skylinesaustralia.com/forums/topic/365434-s-a-u-n-s-w-club-membership-faq/
Its pretty handy if you plan to do any events or want access to the NSW members section :D
I just wanted to mention a side note that occurred while I was installing the intercooler. The kit was not designed with a nipple for a hose on the pipe going into the I.p. So I bought a threading kit and threaded a brass nozzle onto it. I bought the nozzle from autobarn. It looks like this
Some people say it's a power steering sensor something. I'm not too sure what it's for.
Edited by Therealsandybang
  • 3 weeks later...
So. Alot has happened since the last time I posted.
This came out of my radiator. It looks like they used tap water in the coolant when. They were in Japan. After spending hours flushing and reflushing the radiator I got rid of the gunk.
I opted not to use radiator flush. As I didn't want larger pieces to break off and get stuck in my core all at once. Instead I refilled the radiator with water. Ran the car with high heat and aircon on and drained and flushed the fluid with hot water. It worked a treat.
I used nulon llc as it is very close to nissan llc spec. I used a 50/50 llc to distilled water ratio.
Everything is looking nice and new and running well
I got a chance to use a hoist if I helped with an intercooler install for a Rex
I must say it was easy compared to my install no cutting of re bar or chassis required.
He used the autobahn 88 kit. A decent kit for the money but the core was heavy as hell
My radiator flush was done at 80000km
So just had injectors replaced with cleaner better flowing stock items. Spark plugs replaced with iridiums. It took a fair while to remove everything carefully and do it. post-101240-13760080563215_thumb.jpg engine bay as of now.
New wiper modules. They are 35 a piece but they work really wellpost-101240-13760080394241_thumb.jpg new item on left
Sandwich plate for oil temp finally inpost-101240-13760080289188_thumb.jpg it's the red thing
I'm following along too :thumbsup:
Just a word of advice; keep an eye on that oil sandwich plate for the first few days. They have a nasty tendency to develop leaks. Just keep an eye on it and sort out any issues if it gives any.
Yeah man. It's the second one I've been through. The first one was purchased from a reputable Japanese Aftermarket parts company here in Sydney. The sandwich plate I got from them didn't work out of the box. I never went back there because their customer service was abysmal. I was actually really disappointed in them because I heard good things. Anyway this new one has held up so I'm praying it works.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
