Hi mate.
I have build rb25 in the past and found that the motors have a few flaws. stock piston ring landings are weak. oil pump and crank needs a collar, head needs resistors and extra oil drain to return oil back to the pan faster. Hydraulic lifters.
well what i would like to know is from a stock stand point I've been beating my RB20 and it taking it totally stock, my stock rb25 would have died already. now are these motor stronger, I want to know if the head and oil pump has all the same flaws as the rb25.
I'm planning on rebuilding it soon. does the rb20 have hydraulic lifters and oil pump flaws like the rb25.
Dam its a fast little car. lol
My currant mods are Holset hx35 turbo, FMIC, stock BOV, gtr fuel pump, exhaust, 550cc injectors, z32 AFM.
https://www.sau.com.au/forums/topic/426778-gts4-rb20-upgrades/
The motors are essentially the same but a 2WD RB20 is known to be more durable than an RB25 at reasonable power levels (<300kw). I believe that is just the difference in torque output that is pushing the RB25 closer to the limits of its make up, knowing they are produced very similarly.
As for an AWD variant I am confident the oil pump issues will be more prominent like in the GTR's. I am of the opinion the attessa engagement plays a factor in how long it takes a short nose crank to destroy a pump, FWIW this is not fact and is solely my own opinion on the matter. I will know more in time as a friend has recently ventured onto the 32GTS4 w/stag NEO path.
In terms of oil problems all the RB's share this.. I believe the RB26s suffer the most but am unsure exactly why, others will be able to give more detail here and if you should be concerned.
My guess is that RB26s have the breathing abilities inc those throttles to enable sustained high rev running . An RB20 is probably more dirable if thrashed everywhere because of its shorther stroke and smaller diameter lighter pistons . Having the same block deck height means longer rods and a better rod stroke ratio .
If you could do it legally a Neo 25 would be a good upgrade path IMO and has conventional shim on bucket (non hydraulic) valve train . Maybe even a 26 how far do you want to go ?
A .
While there a good motor and fast, keep in mind they will not make 300rwkw like a an rb25/26/30 or even an sr20. The other downfall is there lag and low bottom end torque, due to there short stroke and low displacement. + ontop of that u have the extra weight of a GTS4 to contend with.
B4 rebuilding the motor, i'd 1st be considering any of the above motors, the rb26 will fit straight in
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
