Yeah man, just not worth the time and effort!
Get the genuine gauges.
APEX'i / Defi / HKS etc...
Heaps of people running similar too mine without a hassle! In GTT's i know Martin is, Kurtis is, Ben is......... All similar sorts of brands etc
  • Like 1
Cheap Gauges! Do the job well enough!
Yeah you and other members have cheap gauges, but they are not 'fake'...
It's the 'fake' gauges that are shit and sold at cheap prices.
You say cheap as in they are cheap because they are not the JDM brands (like the ones I have mentioned) but they actually still work :)
Genuine = Works and cost more money.
Cheap = Works and cost less money.
Fake = Does not work and cost less money = Waste of money.
Pretty accurate on mine!
How do you know your jdm gauges are accurate
I use Stack gauges,,,very happy with them and I have tested my water temp and oil pressure and they are both spot on.
Another useful gauge would be Volts.
Cheers
Neil
  • 1 month later...
  • 1 month later...
After having some shitty knock off defis, went genuine and got DEFI's single DIN unit.
Wish I got them sooner. Kit was amazing, everything is so well made and the installation is easy as, even comes with solderless connections.
Left to right, water temp, oil temp, oil pressure.
One thing I've found, on the track, you don't normally have time to look at gauges.
If you can get gauges with a output alarm, it's a big plus, as you can wire it to a led light on the dash. To give you a indication of some thing is wrong.
Just my 2cents
  • Like 1
I'm looking for a digital water temperature readout for my S14. I'd prefer just a small digital readout instead of a full size 52mm gauge or similar.
I know Yashio Factory had the Okachan water temperature gauge (it measured other things too) but this is discontinued and hard to find now.
I'm not sure if it was inaccurate either, as it plugs into the ECU and uses the factory temp sensor. Or maybe that was a good thing, I don't know.
Either way - does anyone know of a similar alternative?
Cheers!
Engine Gaurdian.
Digital display.
Thermocouple temperature gauge and alarm.
Has outputs to control thermo fans at whatever temp you choose.
2 alarm levels, again at whatever temp you choose. Alarms are visual and buzzer.
No Tee-ing into coolant lines so doesn't cause any new potential failures like the popular japanese Tee into the top hose does.
Not dependant on having full coolant to work accurately.
There's a few different models. $120-$150 on ebay last time I bought one. I've been using them for years and have them on all my cars - track car, 4WD, everyday car .
Awesome, thanks mate! Seems like the sort of thing I'm looking for.
Is this right?
http://www.ebay.com.au/itm/ENGINE-GUARDIAN-WATCHDOG-COOLING-FAN-CONTROL-PROGRAMABLE-RELAY-KIT-EG-2-PLC-NEW-/181206306633?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a30bccf49
Also, is there any option to use a normal coolant sensor with it?
that's the one I use. Some can also do oil temp/pressure as well I think.
It uses a thermocouple bolted to the head. Fit it under a thermostat housing bolt.
It doesn't have the option to use a normal coolant sensor.
It is better than a normal coolant sensor because it doesn't have to be immersed in coolant to read an accurate temperature. ie if you get a leak, a gauge using a normal immersed sensor is useless - it can even read cooler than normal when the engine is overheating.
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the re003s’ on my 06 XT Forester Turbo and I highly rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
