I have recently bought a 96 import r33 gtst and i am having some problems, firstly being boost, the stock boost gauge just barely gets past 0 at the high end of the rev range (cant see exactly because tacho is not working atm which is another story).
The other thing which could be related is there is a high pitch whistle noise which doesnt sound right at all which sounds like its coming from around the turbo when it gets to high revs. I cant see any apparent split hoses, could this be a leak on the manifold side?
Any advise would be much appreciated before i start dismantling on the weekend.
Hmm no its a different noise, it wont get close to boost till high revs and then it starts making the noise and will get to maybe +1 mm/hg at the most.
Ill have to get a vid of it tomorrow and post it up.
No the car wasn't exactly cheap. Tonight i disconnected the bottom vacuum line from the stock solenoid and i seemed to make 6-7 psi, was about half way from 0 to 7 mmhg. I also got a clip of the noise:
Sounds like a fat exhaust leak. Check for obvious visual signs. You should see black carbon deposits n shit from where the leak is. Since you said you aren't making boost, I'd check for the obvious signs around the manifold to turbo gasket. Then check turbo to dump pipe. Mine made that exact same sound. The metal gasket between the turbo and dump was split from reuse. Don't get those paper kind of gaskets, those two shiny things on the black shit. They are shit, piss weak and don't last. Get the proper metal gasket. I don't think a failing turbo would emit that sound. My car when I got it had surprisingly loose mani to head nuts. I tightened those up quick fast.
hmm, i was going to pull it all apart this weekend but i cant get the replacement gaskets till after monday through nissan. Thanks for the info, might pull a few things out of the way and have a look for signs of a leak as you say. Not that i can see it very well but i think there is a broken stud on the manifold to head too.
It sounds to me that it's not an exhaust leak. Probably the Turbo is gone but also check the Blowoff valve to see if it's fallen loose. This happened to me and turned out the BOV had given way over time.
  • 3 weeks later...
All the nuts on the turbo to manifold were loose, i tightened them up and ordered a new gasket. Would this be enough to cause complete lack of boost or is it likely to have a boost leak somewhere as well? car seems to be running very rich especially at idle.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
