Did a search but came up with nothing, so has anyone made their stock 34Gtt plenum forward facing by blanking the original entry point and making a new throttle body mounting plate on the front? Would this actually work or be bad in regards to flow? would like to get rid of the excess pipework across the front of the engine, along then across the engine to the throttle body and the aftermarket FF plenums sound like a P.I.T.A gettting the AAC and everything else connected and working.
Fors and against please guys, and if anyone has done it pictures please.
Because the standard plenum was designed (by some very clever Nissan engineers) to have the air enter from the side and distribute it evenly to all 6 cylinders. That is not a trival exercise, given the shape that the plenum is. You can bet your last buck that there's some rather clever design ideas hiding inside there. It's not just a box.
Chop and change it the way you describe, and despite the people out there who have done it and therefore have a vested interest in defending the results (so they don't look stupid) or are actually ignorant of the results (poor air distribution), what you will inevitably do is wreck the distribution between cylinders. The box was designed to receive air from the side, now it's getting it jammed in from one end, and the box has NONE of the design features that you'd expect to see in an end-fed plenum.
Ok, that's sort of what i was thinking but wanted confirmation. So my only real choice is to fork out heaps of $$ for a FFp and new throttle body and the dramas that come with fitting one i am guessing.
  • Like 1
dunno what GTS kid just said but look at the GTR, those clever little engineers at Nissan designed the forward facing plenum and that didn't cause "uneven air distribution" as he described.
I agree don't chop it tho, leave it or get a good greddy copy instead
Seriously, are you just following GTS around trying to flame him? No relavance to GTR plenum, his comment was regarding forward facing the stock Gtt plenum.
This is the epitome of retarded. Yes, you are correct, Nissan did design a forward facing plenum and yes it does work. But he is quite obviously talking about the RB25 inlet plenum, as is everybody else because that is what the thread is about. He is talking about the uneven air distribution that is created when you convert a standard RB25 side feed (for lack of a better name) plenum to a forward facing one. He is not talking about a the RB26 plenum which was DESGINED to be forward facing.
Using your logic converting the RB26 plenum to side feed would not have any "uneven air distribution"
Anyway, to OP, yes you are better off leaving the standard inlet plenum as it is or puchasing a greddy/plazmaman etc one. As has been stated a standard converted plenum often leans out cylinder 6. Using a forward facing plenum you get power loss in the low/midrange.
Edited by iruvyouskyrine
Why not? You can run a cooler pipe Gibson style from the drivers side over the top of the cam covers.
Cheers Wolverine I will google/search Gibson style, is it similar to gangnam style? :P
Thanks for the input guys.
He is not talking about a the RB26 plenum was was DESGINED to be forward facing.
Um if u look at the RB26 plenum, the 1st 3 cylinders get the majority of the air according to GTS boys theory because its forward facing, but this isn't true. All the cylinders do get even airflow despite the forward intake being closest to the 1st 3 cylinders.
Anyway it was a silly idea by OP, i wouldn't mess around with plenums, get an aftermarket one if that's what u wish
You are totally missing the point and comparing apples to oranges. It has even air distribution because it was DESIGNED, i repeat, DESIGNED to be forward facing, unlike a modified standard plenum that was DESIGNED to be side-feed and has been modified to be forward facing, hence having uneven air distribution. If you cannot understand this, then i truly feel sorry for you.
Sorry OP, as i said before your only real options are
- Standard plenum
- Std plenum with different crossover piping as shown by Wolverine
- Plazamama/Greddy forward facing plenum
If you already have a NIStune or aftermarket ECU, and are willing to give up traction and cruise control then you can use an RB25DET Series 2 Throttle body, and it will work fine with your car. The standard 25 Throttle body is exactly the same as the one in the post wolverine made, and will allow you to run that crossover piping no worries :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
