Hey guys, i'm pulling apart this engine as it was blowing smoke, suspected headgasket but it looked fine when pulled apart.. Cracked piston and/or blown rings? The engine had approx 145,000 km on the clock - pretty much everything is for sale:
Have added a few photos below, more available on request ! If you need any random parts or hoses off it let me know. Located in Sydney for pickup or I can post anywhere
Rb25det head - includes rocker covers, cams, valves, etc etc, everything except the exhaust cam - $300
HKS exhaust cam gear - $150
upper and lower timing belt / cam covers - $80
CAS - $80
intake manifold - $50
harmonic balancer - $80
sump, oil pickup & all bolts - $80
oil dipstick - $20
AAC idle valve - $75
S2 coilpacks - $100 / full set
S2 coilpack loom - $50
standard turbo oil & water lines + banjo bolts - $50
standard injectors & fuel rail + FPR - $100
Alternator - $80
P/S pump - $100
A/C pump - $100
Anything else.... chuck me a PM or reply here !
https://www.sau.com.au/forums/topic/427115-stripping-complete-rb25det-engine/
  • 1 month later...
Hey buddy interested in turbo lines plus all banjo bolts, If you have the turbo outlet compressor pipe, and coil packs plz. Price and I'm from melbourne
  • 3 weeks later...
do you have the vct head oil drain line?
Sorry late reply.. i've still got it. if you're keen PM me !
Hi mate is the head series 2??? Can you please SMS me on 0422193418 thank you
Sorry mate the head is sold
hey mate just wondering if you still have the oil and water lines with banjo bolts still available?
Yep still have them, PM sent
Do something on the cross pipe, bov, intake manifold, turbo lines and banjo bolts? $$
Pm me ur best price pickup on them all!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
