I have 24mm front and 22mm rear non-adjustable but that's cause I bought them for a steal at $150 for the pair. The car does have a bit more roll than I'd really like but is really very predictable when drifting on track at fairly high speeds (3rd gear 100+km)
Good to get more feedback, but i guess its not just the bars its the whole setup that needs to work together :)
Massive amounts of info here!
My thought process is:
1. Tein work pretty closely with Nissan so therefore my springs are matched nicely
2. Whiteline would test their products before releasing them and therefore HD front should match up to HD rear?
With the adjustable ones, do they set themselves looser or tighter than fixed? ie. does the second mount point go harder or softer than the equivalent fixed bar?
But how do they compare to a fixed bar?
From what you guys are saying, combined with checking out the specs on the site, I'm thinking I might go BNF24Z (Front, HD, 24mm, 4 point adjustable) and BNR11XZ (Rear, XHD, 22mm, 2 point adjustable).
No probs. They compare exactly the same as the fixed bars. The only difference is you have the flexibility to adjust if required. The only reason someone wouldn't get adjustable is if they didn't want to spend the extra. But to me, if your talking $50-60 a bar difference, just get adjustable and know that you can swap it around if required. I've never adjusted mine after installation, but one day it might be fun to try out and see what different settings do.
  • Like 1
Errr man, that is a bit big.... What you measuring boi? :P
I would like to see how such big bars go anywhere near the body mounting locations!!
FWIW, it pays to remember that bar stiffness goes up with the 4th power of diameter. On that basis a 33mm bar is more than twice as stiff as a 27mm bar, and a 27 is already more than twice as stiff as a 22. Ergo, a 33 would be simply massive stiffness on a road car. Massive.
Check measurement with proper vernier required.
hrrrrrrrrrmmmmmmmmmm well i used a ruler and then measuring tape...still got the same measurements. maybe i need to go back to primary school? totally fine with someone coming to check them out for me too =)
Lolololol..... All good, but i think your "tools" are a bit primitive :P
Good point my setup is as follows:
BC BR Coilovers 8kg F 6kg R (whatever the standard spring rates are believe that is correct)
Whiteline swaybars as before (24mm F 22mm R)
I also have lock collars for rear subframe (whether that makes a difference)
Adjustable arms all over and locked out my hicas
Similar setup to mine but i have the 27mm and 24mm bars...
  • 1 year later...
What about 24 at the front and an adjustable 24 mm at the rear?
Per my first reply in this thread I have 24mm adjustables front and rear on an R32. So, not an R34, and therefore possibly a bit different. Nevertheless, having recently replaced all the other suspension components on my car (the new springs being a bit stiffer than the old ones) the adjustables are set the same as before (hard at front, soft at rear) my car has a definite tail happy characteristic mid corner. I take that to mean that what I posted in my first reply is even more valid than before - which is that your mileage may vary. What result you get really does depend on everything else in the car. R34s seem to require a little more bar at the front. So if it were me thinking about fitting 24s front and rear on a 34, I would still only do so with adjustables both ends so that I can add stiffness at the front as well as remove it at the rear.
If I were running stiff coilovers on a 34, I think I wouldn't go further than 24F22R (adjustable). If I were running Kings or similar springs that are not much firmer than stock, then I might prefer 27F24R (both adjustable still).
I don't see the value in saving a few $ on buying a fixed bar if there is an adjustable bar available. If you buy the fixed, you have to live with the result. You'll never know if it could have been just a bit nicer if you'd been able to adjust it.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
    • Just a reminder orange park was cool back in the day   and drifting the main circuit was even cooler   f**k I miss that car
    • We used Knox Drive shafts years ago when we were doing gravel rally, good guy but I heard it had changed hands? He's got a lot of stuff and is miles cheaper than GJ and so on. He used to have a lathe setup with a MIG torch on the tool holder so he could get the uni welds just right, quite a clever guy. I just got a driveshaft done for my sequential installation and that was through Balancing Services Australia in Preston, they did the Gibson cars in the old days. New genuine CV's, billet yoke, new centre bearing and chome moly shaft was $2k.
    • Thanks for sharing that mate, I've got a couple of spares on the shelf but all the unis are tight....will give old mate a shout. BTW are you sure it wasn't just a $400 paint job? Any detail of what they replaced (cut/reweld?)
    • Yeah I saw that about the US Q50 recently, apparently it was shown to Inifiniti dealers (probably to help with their depression about the cars they can sell). Seemed like a really obvious step to me, the platforms are very similar in many ways. Even if there aren't many people who actually put the money up it should really help with image/reputation. What hasn't been clear anywhere if that is a V38 model of if they are just going to add the trans as an option in a new model year. What they did with the Z from 370z to "Z" is just weird so I'd be surprised if they released this as a V38. Great news for me to have an option; it is far from confirmed that I can get any decent track sessions through the auto so having a manual I can swap to is great.
